Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 12th March 2010, 04:22 AM   #1191
cviller is offline cviller  Denmark
cviller's Avatar
The tech diy kit uses one 50ohm instead of two 100 in parallel - thats why you don't see a R7 on the list.
Yes you can bridge them, but perhaps it is best to build them first and then bridge them afterwards. You'll need balanced inputs to get more power.
I have started a blogged guide to my F5 boards read it here: F5 pcb v2 blog
Old 12th March 2010, 07:57 AM   #1192
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
cviller, can you point me to a part # that will work on your diode pcb's for the heatsinks?
Need to put these black beasties to work.
SemiSouth R085/R100A JFET available now
DCB1/BiB #3 on order : SSHV2 Sign up Sheet/Payup Sheet Ends 2-26-2012 CLICK HERE
Old 12th March 2010, 04:03 PM   #1193
cviller's Avatar
You can get the right heatsink at mouser. Here is the illusive rectifier thread:
Gb: Rectifier boards
Old 12th March 2010, 05:19 PM   #1194
Renron is offline Renron  United States
Renron's Avatar
Tea-Bag,
You'll find that those boards make for a Dead quiet power supply! Use the snubber option and Ultra fast diodes you'll virtually eliminate any "ringing".
Make sure to use some type of mounting device (bolt or clip) to secure the diode to the Heat sink or you'll hear about it from Christian!!!
I'm glad I did.
Beautiful boards!
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
Old 15th March 2010, 09:29 PM   #1195
Hi, I am very very new to DIY AUDIO, could you please explane how I can purchase two amp PCBs and two Power Supply PCBs
Old 16th March 2010, 05:12 AM   #1196
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Christian , I need to order rectifier boards and plan to use the snubber option , do you list the values for the snubber.
Old 16th March 2010, 05:55 AM   #1197
cviller's Avatar
Last time I did some reading about it, 100 ohm and 22-100nf appeared to be what most people were using. But if you want to find the best value, you need to measure with a scope or follow the guidelines specific to your diodes.
I have collected a few hints in this thread: Gb: Rectifier boards
Old 16th March 2010, 05:57 AM   #1198
cviller's Avatar
Hi esprit, you can order from me at my order site: GB order page for cviller you might also want to check out my blog (in my signature), where I'm trying to collect information as a guide to f5 builders.
Old 18th March 2010, 04:31 PM   #1199
acold7dusta's Avatar
Got my new boards last Friday...appreciate the smooth transactions!
Squeezebox Touch>Coax>MH Dac 25.2>Marantz PM-15S1>Seas Thor (Small)/Beyerdynamic DT770
Old 22nd March 2010, 03:10 AM   #1200
OliG is offline OliG  Canada
Received the boards last week, they look really nice !
Thank you Christian.
Page generated in 0.12958 seconds (76.42% PHP - 23.58% MySQL) with 10 queries
