| Group Buys Members group buys |
#631 |
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#632 |
Peter,
Just starting to put the F5 boards together and noticed that the BOM does not include any small caps for the psu board and checking your photo it seems that you do not populate them. So is it just the four large caps plus either 4 or 8 resistors (for 5W or 3W versions) on the psu? Thanks Alan |
#633 |
#634 |
Peter,
Are the parts in red on the second attachment an update or correction? |
#635 | |
not politcally affiliated
Those are update to the original circuit. Nelson changed it later on. These values will work more better. |
#636 | |
![]() The picture also shows what resistors I'm presently using.
#637 |
That assembly will be mounted between two tall heatsinks.
#638 |
Peter,
So two capacitors per channel - what look like Caddocks, Mills and Rikens resistors, but.... how do you attach the output devices to the heatsink - it seems that they must be mounted near the edge of the heatsink.? So is there anything left on the capacitor board? Would you be using the copper bar then as your star-ground? Alan |
#639 |
There are two more caps on the other side, as to resistors I used whatever I had available. I will be using only rectifier section from capacitor board. The copper wire bridging the caps will be indeed the star ground.
#640 |
Peter,
So that is one channel? If so then I take it the caps at the back are also attached to that one board? Yet again it looks like a work of art in the making. Alan |
