Group Buys Members group buys
F3 and F4 Clone PCB Reissue group buy, also F5 PCBs
Old 29th January 2009, 03:22 AM   #551
Diomedian is offline Diomedian  Canada
Originally posted by samsagaz
About R13 and R14, wich of this two Res will be better?
http://search.digikey.com/scripts/Dk...e=P47.0CACT-ND
or
http://search.digikey.com/scripts/Dk...CMF47.5QFCT-ND
and what about yageo brand?
http://search.digikey.com/scripts/Dk...ame=47.5XBK-ND
Well, i cant find any 0.47R 3W res in Digikey or Mouser to work on R11 and R12 someone know wher ecan i get it
Thanks in advance.
Some claim there is very little difference between resistors, and others would claim there is a large difference. You'll find any of these three fine, though the only way to find out which one you prefer (if any) is to try them all.
Here is the typical .47R 3W resistor used in these parts.
http://search.digikey.com/scripts/Dk...=P0.47W-3BK-ND
Old 29th January 2009, 03:25 AM   #552
samsagaz is offline samsagaz  Argentina
About Capacitors for Power Supply you wich of this will be the best Choice?
http://search.digikey.com/scripts/Dk...&name=P6671-ND
http://search.digikey.com/scripts/Dk...name=P10628-ND
or more cheap
http://search.digikey.com/scripts/Dk...me=565-2880-ND
Old 29th January 2009, 03:27 AM   #553
Ok Thanks, will order these Resistor!
Old 29th January 2009, 03:37 AM   #554
or more cheap
I forgot to note above that those Yageos are larger than the lead spacing on Peter's boards. If you get those, you'll need to stand them on end, but as noted by Peter and others, there should be no problem doing this.
As for the caps, the first and third ones will work fine. The second one won't fit on Peter's board, as it has too many pins (four or five)
You may find it handy to learn to read the manufacturer's data sheets that are linked on both Mouser's and Digikey's sites. They contain all the info you need to know as long as you dig for it a bit.
-j
Old 29th January 2009, 04:50 AM   #555
-j
Well thanks too much again! i see what you say about the size of the res, i will purchase the small ones.
Last question for today... About Diodes... the BOM file that i have recommend me 844-MUR3020WTPBF (200V 30A) that cost 2.62USD, is OK to use just Mur860 ones? i found that they just cost 1US instead 2.62.
Will get worst sound using Mur860 than MUR3020 ? 30A is not a little big for this app?
Old 29th January 2009, 10:20 AM   #556
woodturner-fran is offline woodturner-fran  Ireland
Double check the data sheets, but IIRC, the MUR860 doesn't have enough current capability. Might be ok if you are going dual mono though.
Fran
Old 29th January 2009, 11:21 AM   #557
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Default Diodes
Fran
Sams,
Consider these if ordering from mouser, small, less expensive, high current capable.
512-FFPF30U60STU
Old 29th January 2009, 01:50 PM   #558
ok, thanks for the tips, will check the 512-FFPF30U60STU
I just want to let you know that i will build all Dual Mono Amps.
what Kind of transformers i need to use if u use Dual Mono?
Old 29th January 2009, 02:53 PM   #559
Elsewhere in this thread, or in the other F5 thread, 300VA 2x18V transformers have been recommended. In general, toroidal transformers are used due to lower EMI (when properly oriented).
-j
Old 29th January 2009, 05:27 PM   #560
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
F3 and F4 Clone PCB Reissue group buy, also F5 PCBs Send a message via AIM to Peter Daniel
The F3 amp boards are officially sold out, still have all the other boards available.
To order kits contact me through forum mail.
F3 and F4 Clone PCB Reissue group buy, also F5 PCBsHide this!Advertise here!
