F3 and F4 Clone PCB Reissue group buy, also F5 PCBs F3 and F4 Clone PCB Reissue group buy, also F5 PCBs - Page 2 - diyAudio
Group Buys Members group buys
Old 29th November 2008, 08:23 PM   #11
jonclancy is offline jonclancy  United Kingdom
Thumbs up Almost There!
Just a couple of board requests to be placed and we're there!!!
Many thanks to everyone for supporting this re-run, and to mithomas, PD and NP for making it possible!
Cheers
Jon
Old 29th November 2008, 08:44 PM   #12
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
F3 and F4 Clone PCB Reissue group buy, also F5 PCBs Send a message via AIM to Peter Daniel
Before we can proceed any further,, it needs to be cleared out with Mr. Pass: http://www.diyaudio.com/forums/showt...61#post1661961
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 29th November 2008, 09:15 PM   #13
Good point, Peter. I hadn't realised this was going on.
I hope a workable solution can be found.......
Jon
Old 30th November 2008, 06:39 AM   #14
khundude is offline khundude  Canada
Are there ever any plans for a F1 buy? I am building a full range OB and need F1 boards.
Old 30th November 2008, 12:17 PM   #15
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Default F1
Have you considered an F2?-easier build if doing it P2P. I did it on a perf board, and it came out fine. Need to keep the Source resistors way off the board...
I use the F2 to drive pro-woofer in an OB.
Old 30th November 2008, 10:50 PM   #16
Default Re: F1
I want to go the full balanced route because the rest of my system is balanced.
Old 30th November 2008, 10:57 PM   #17
OK, which one is going to drive an Audio Nirvana Cast Super 12" better with a gain of 14 on my tube pre. I can set my I/V stage at 4 volts to double the gain. I love good tube sound, not fat and loose. I figured that if I was to use a two SE F3's or a balanced F4 it would be a good way to go but I really want to hear what a tansconductance amp can do with a full ranger. If I were to make a balanced F3 or F4, what would it be?
Old 30th November 2008, 11:35 PM   #18
Tea-Bag's Avatar
Brings up a good question. I am not sure if you can use F3's to run balanced in the same mode that an F4 can.
Old 1st December 2008, 02:01 AM   #19
I was thinking that too. Two SE F3's or one balanced F4. How many boards do I need to run a balanced F4?
Old 1st December 2008, 03:51 AM   #20
fredlock is offline fredlock  United States
Just added 2 PS and 2 F4 pcb on the wiki.
F3 and F4 Clone PCB Reissue group buy, also F5 PCBsHide this!Advertise here!
Copyright ©1999-2017 diyAudio
