Group Buys Members group buys
my_ref revC group buy (Mauro Penasa LM3886 design)
Old 5th February 2009, 04:36 AM   #521
pinkfloyd4ever is offline pinkfloyd4ever  United States
Default Weeeeeeee Confetttttiiiiiii For All!!!!!!
YAAAAA got mine too again, you guys are the sh!t! We each owe Uriah and Peter a beer or 12
I love all the notes on the PCB...Russ' doing I assume? Any reason not to socket the LM318? Could someone explain the 2 ground planes? And why one of the big 'lytics + side is tied to the same place as the - of the other big 'lytic? I know I should read the original thread, but it's SOOOOO long. Anyone know where to find a semi-detailed circuit explanation (in english) without having to read all 120+ pages?
And you guys really outdid yourselves with the printed tape part labels & heat sealed packaging ...did you already have equipment to do that?
Old 5th February 2009, 11:39 AM   #522
udailey is offline udailey  United States
Passive Aggressive
Pink,
As another guy posted we should move these type questions to the SOOOOOO long thread.
The board is all Russ' doing. The lytics tie +and- to make a ground because, technically, you dont earth this board. You just take the secondaries and tie them together in the middle which cancels out their voltage on those ends making 0V and then that 0V plugs in where the +and- of the lytics are. The 'second' ground is connected to the first with a 1R resistor making is still kinda ground but I suppose that keeps the signals from wanting to mix with the noise from the power ground. Make sense?
I personally have one channel that works perfectly and one that doesnt. Perfectly is a kit channel and not perfectly is the prototype. Scary huh? Anyway the prototype probably has a problem cuz there is no soldermask. I have to actually ground it to earth to get it to stop humming and it has issues with capacitance on my speaker wires. The other one, the kit one, has no problems.
Go ahead and socket it. No reason why not. I mean what if you zap your opamp some day with some ESD? Might be nice to have that socket.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 5th February 2009, 01:25 PM   #523
troystg is offline troystg  United States
troystg's Avatar
Pink-
"Any reason not to socket the LM318? "
Because the circuit was designed for the 318 and sockets are usually intended for trying other pin compatible opamps or in "risky" circuits.
Mauro's schematic and Russ' PCB are ROCK solid and if the PCB is assembled correctly the chip will last a LONG time and not give you ANY issues.
So I didn't want to add the extra potential points of failure.
It wouldn't hurt, but there is no reason to.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 5th February 2009, 01:52 PM   #524
schro20 is offline schro20  United States
schro20's Avatar
Default Nylon bushing: how to drill your holes
For those preparing heatsinks it may be good to know that exact sizing of the nylon bushing for the insulation on the chip. It is part 3102 in this table: http://www.keyelco.com/pdfs/M55p122.pdf
Note in particular that the nylon neck is longer than the chip is thick, i.e., it sticks out and some of it needs to be sunk into the heatsink.
Peter
Old 5th February 2009, 01:55 PM   #525
troystg's Avatar
1/2" unibit comes in VERY handy.
Troy
Old 5th February 2009, 01:58 PM   #526
schro20's Avatar
Default color coded BOM
Attached is the BOM color coded according to the bags. Yellow is the capacitor bag (everything small is labeled EXCEPT for the 12 220nF bypass caps [small yellow boxes] which correspond to C7/17/18/19/20/21). Blue is for the resistor bag (everything labeled except for the big cement 0R47). The "silicon" bag is highlighted in pink here. Note that the nylon bushings are in that bag loose. So when you open the bag, be sure not to have those little buggers roll off under the couch...
Peter
Old 5th February 2009, 03:05 PM   #527
Coreyk78 is offline Coreyk78  United States
Coreyk78's Avatar
Originally posted by troystg
Didn't he do an OUTSTANDING job at packing them!?!?!?
Is he still stuffing them with confetti?
Yes it was packed extremely well, and the confetti did its job!
Old 9th February 2009, 11:06 AM   #528
Tony X is offline Tony X  France
Tony X's Avatar
Thanks to all beginning with Mauro!!
My package was posted on the 4th and arrived here in France to-day on my birthday. You could not have done better.
Now the fun begins putting it together.
BYE
Tony
Parfois, martyr lassé des pôles et des zones
Rimbaud - Le bateau ivre
Old 10th February 2009, 03:35 PM   #529
earsandeyes is offline earsandeyes  Netherlands
earsandeyes's Avatar
Package arrived today, everything seems in order.
Great work guys, thank you very much
Michiel
Old 10th February 2009, 03:38 PM   #530
troystg's Avatar
Anyone in the US put one together yet?
Troy
my_ref revC group buy (Mauro Penasa LM3886 design)Hide this!Advertise here!
X-Calibre : Hot Rodding Mauro Penasa's LM3886 design rudi Chip Amps 171 19th January 2013 09:38 PM
MY_REF EVOLUTION by MAURO PENASA goldkenn Chip Amps 8 25th September 2007 04:50 PM
Mauro Penasa's My Reference 3886 "RevC" supra Chip Amps 6 1st April 2006 05:37 AM
Audiosector/Chipamp LM3875 or Mauro Penasa's My Reference RevC from Twisted Pear blottojon Chip Amps 14 8th March 2006 09:48 AM
Copyright ©1999-2017 diyAudio
