Hello
I would like to ask for some help.
I want to build a all J-Fet preamp design by Borbely audio which uses J510 or J511 regulator .
Unfortunately these parts are no longer available .
Can somebody give some advise for substitute these part .
Thanks for any help ,advise etc .
http://www.borbelyaudio.com/adobe/ae699bor.pdf
Greetings
Greetings
HI Choky
Thanks for your help !
Can you explain how I use J-Fet and trim pot instead that 2 legged IC .
I have 2SK264BL or 103BL or 2SJ74BL,GR or 2SK170BL,GR.
I would like to ask you for a little help more .
I only understand electronic stuff in a schematic .
Can you help me with these .
I ordered some 2SK389V . Only problem to me these regulator . I do not want to give up on these project because that regulator !!!
For power supply I will use the +/-36V .I have a toroid 2x25V.
Thanks for your help .
Greetings
Greetings
Thanks!!
HI pchw
I just placed an order today morning so let wait until they answer to my order . The stock shows they have !!!
If yes I will let you know certainly.
I don't want to post the store name in vain , you know I don't want spread false info .
Thanks for your patient .
Greetings
Greetings
gaborbela said:HI Choky
Greetings
look at picture - taken from Papa's Diy-opamp article ; just use adequate multiturn pot instead of resistor
regarding regulator - on which one you exactly think ?
btw - 2x25V will hardly give you +/-36V after reg ; you need more volts ...... but I can't tell you how much more without knowing exact topology you are planning
Hello Choky
Thanks for your advise and help.
I posted the website at my first post were I ask for help .
If you open the site and take a look Figure 17.
That is the pre I would like to build next to my Aleph 1.7 preamp.
I'd like the design a lot because all Jet preamp .
Unfortunately I'm unable to take the schematic and post here that is why I posted all the writings etc .
One more time , thanks for your help.
Greetings
Greetings
2SK389V still avaleble in USA
Hello PCHW
I promissed I inform if I found the asked J Fet
Here is the address .You will decide if you want to spend that much money on .
http://www.ka-electronics.com/FETS/FET.htm
If you need it badly you will better to buy it until you can get it .
It will be more expensive by the time that sure .
Greeting
Hello PCHW
Greeting
J510 or 511 regulator needed 2PC or advise for substitute them
HI Choky
Please don't forget me if you can please help me .
I already spent a lot of monet on these project so it would be better to back up now .
I know is not easy and I appreciate your advice and help
Thanks Choky
Greetings
HI Choky
Thanks Choky
Greetings
Re: 2SK389V still avaleble in USA
Thank you, Gabor!!
gaborbela said:Hello PCHW
Greeting
Thank you, Gabor!!
Hi Gabor,
Extreme-A amp uses the same current regulator J511/ J510. I didn't have any luck findng a store selling it. There are some on the web but the minimum order is like 300 or 500 pieces. I was advised by a co-DIYer that I can use 1N5314, which has almost the same spec as the J511. It's also available at Mouser. Why don't you give it a shot, I think it will work.
Here's the datasheet of 1N5314, http://www.centralsemi.com/PDFs/products/1N5283-5314.pdf
Good luck,
Fred
Good luck,
Fred
Re: J510 or 511 regulator needed 2PC or advise for substitute them
I'll be back .....
edit :
I'm back ........
see :
use any decent little bjt from your drawer
Please don't forget m.......
I'll be back .....
edit :
I'm back ........
see :
gaborbela said:Hello Choky
Do I use PNP or NPN .
I have both .
MPSA42 or MPSA92 ???
Which one would be better .Sorry if is a stupid question but I do not want to damage the $13/PC 2SK389V Jet . I'd rather be safe than after sorry .
Greetings
you must look at schmtc
both are NPN
HI Dodo
Thanks for the schematic ! What do you mean the right 2SK246BL pair for cascoding .
I just planing to use a matched pair that is all .
Do I need something special matching here ?
I think if I match them to 0.01V that will be OK or not???
I have some mathed pair at home . I really hope that will do the job.
I want to build these preamp because all J-Fet and I want to here it how will com pair with my Aleph 1.7.
I know the Aleph pre one of the best sounding from Mr Pass design .
Greeting
Greeting
Hello Dodo
I just printed out your schematic and com pared your schematic with the original , you left out 1pair resister 1M close to the output .
Do I have to use all those capacitors in your schematic ??
Mr Borbely schematic only has capacitors on the output . What is the purpose all those caps ? An what type of capacitors do you think electrolytic ?
What about values 100uf any advise ?
I'd like the original schematic posted by Mr Borbely because only 4 capacitors and no electrolytic .But may be your schematic is the comp let verision ?
Would you please comment those capacitors I'm getting a bit confused .
Mr Borbely only wrote about the 50R trimmer pot to balance the two side of the 2SK389V . But after he write may be it is possible I do not need that all .
He does not write nothing at all special matching for the cascode 2SK246BL.
Greetings and thanks for your help .
Hello Dodo
I'm sorry being so stupid I just see you use one electrolytic each side the rest foil caps or pp or what ever .
Can you give some hint what value do I use , of course please let me know what if I don't use any of those capacitors at all?
Can you comment those capacitors necessary in here, and why .
I do hate capacitors but when there is a need for them of course I use the to .I'd rather say I try to avoid them when is possible .
Thanks one more time .
It looks like somebody offered me the substitution for the J511.
But I want to give a big thanks for Choky and dodo for you to .
Greetings
Greetings
- Group Buys
- J510 Regulator or substitute needed
