| Group Buys Members group buys |
#231 |
#232 |
Just DIY!
Did anyone compared it to Salas's SSHV2?
PREAMPs : AMB α10 + JC-80 clone | Balanced DCB1 | AMPs: AMB β24 | Aleph 5 | Symef | Hiraga | ML-2 | Fetzilla | Telos 390 Clone DACs : TPA Buffalo II + NTD1 I/V | TPA OPUS + IVY III Speakers : Jim Holtz Statements | Astasia SD | Tubasson Mark 2 |
#233 |
Hi. I have a new batch of PCB available. Quantities are limited. Send me a private email for details. Thanks.
#234 |
Pinnocchio you have mail. Orders are starting to fill in. I ordered just a small batch so if you want the PCB this is your chance.
#235 |
Just DIY!
Sorry, I'll have to pass this time...
Starting a new project so my Tubes will have to wait some more... Thanks for making this available to the DIY community Do
#236 |
PCB received today. Only 18 left. Send me an email if interested. Thanks.
#237 |
Selling fast, only 12 boards left. Send me a private email if interested. Bye.
#238 |
All kits where shipped today. At the current rate of sale, I'm planning I'll have PCB available for only 2-3 more guys...
#239 |
Only 10 PCB left...
#240 |
Hi.
I was hoping someone could help me trouble shoot this circuit ? The board passed the 15V only tests fine. When I apply the HV, things go pear shaped. I followed the test steps. When I power on, I get no voltage reading across R12 (it's supposed to be 250mV). Furthermore, adjusting R3 does not alter the VReg. After poking about with my multimeter, I got the following readings at the opamp : pin 2 = 7V (fine) pin 3 = 1.2V (wrong !!!) pin 6 = 0.9V (correct for mostfet shunt) pin 7 = 10.6V (correct) Checking other voltages, the voltages immediately after T2 are way low. RAW DC coming in about 300V, but after T2 the voltages are 65V. What should the initial position of R3 be ? The documentation has no mention of a default value ... A big but though ... For about 5 seconds after initial power on, everything looks like it's going to behave, with realistic voltages at the outputs, but then they suddenly drop. If there's any more info you require, let me know. I'm at my wits end ! |
| How about shunt regulatorH | uhcmos | Solid State | 4 | 2nd March 2007 09:32 AM |
| Shunt regulator | tubee | Tubes / Valves | 12 | 2nd March 2006 01:08 PM |
