Group Buys Members group buys
HV Shunt Regulator PCB
Old 26th January 2010, 11:02 PM   #211
Radioman62 is offline Radioman62  Sweden
Thumbs up Tested my two regulators today
At last I have done the checking test on my two cards .
They was soldered and ready 10 month ago ., (almost finished at post #178).
But I havent really got the time and was also a bit afraid of what the stress and concentration this function test would do on me
I mentioned back at #178 I would try a National Semi LME49710 OP Amp. I did and it worked OK. Less then 2mV hash on scope.
I also did one card with an SMD OPA656. All DC levels measured the same and the regulator also worked OK i thought, until I measured and looked at the scope. I have a perfect 63MHz sinewave of 130mV ripple (RMS) So we are a few having radio transmitters instead of regulators, allthough mine has a weak oscillation.
I havent "listened" to any of them yet. I will try to get rid of the oscilation on the OPA656 one first. C13 maybe? I have not checked the T5 CCS. It should be more then 3mA. Could this have something to do with the small oscillation?
Anyway. More of you have to get your cards ready so that we can compare our results.
Cheers// Ove
Old 27th January 2010, 07:15 AM   #212
bambadoo is online now bambadoo  Norway
Thanks for the information. Haven't build mine yet...
Old 1st February 2010, 07:07 PM   #213
Kamel is offline Kamel  Germany
Send a message via ICQ to Kamel
Is there an alternative Source for LND150?
Best regards
Felix
Old 2nd February 2010, 03:49 AM   #214
Audiohifi is offline Audiohifi  Singapore
BSP135 can be used to replace LND150
But you have to solder wires to the legs feed wire to pcb
Audiohifi
Old 2nd February 2010, 08:33 AM   #215
You'll mean the BSS135.
I can't also find it
Best regards
Felix
Old 2nd February 2010, 08:55 AM   #216
massimo is offline massimo  Italy
BSS135 (T092) are no longer manufactured by Siemens, replaced by the SMD version BSP135 (SOT-223)
Old 2nd February 2010, 05:20 PM   #217
Okay I'll see.
Thanks a lot!
Old 31st March 2010, 08:31 PM   #218
M Knight is offline M Knight  United Kingdom
Mouser supplies LND150.
Old 31st March 2010, 08:54 PM   #219
I'm reaching here, but I'm wondering if anyone who bought the HV shunt regulator boards has two that they no longer want. I screwed up royally with two of mine, and would like to start afresh with two new boards.
Any offers? You will be amply rewarded.
Old 24th October 2010, 08:14 AM   #220
danFrank is offline danFrank  United States
Hi I was wondering who have finished their HV Shunt Reg boards and have them working properly without Oscillation.
What op amp did you use? Anybody get this board to work properly (no oscillation) with the OPA656 op amp?
Thanks, Daniel
HV Shunt Regulator PCBHide this!Advertise here!
How about shunt regulatorH uhcmos Solid State 4 2nd March 2007 10:32 AM
Shunt regulator tubee Tubes / Valves 12 2nd March 2006 02:08 PM
