Group Buys Members group buys
Interest in dual regulator LT1083 pcbs?
Old 12th August 2008, 12:09 PM   #31
woody is offline woody
Was that $22 for 2 or 4 of those small boards? What were the
larger boards in the picture?
Old 12th August 2008, 02:50 PM   #32
h_a is offline h_a  Europe
h_a's Avatar
Hi woody,
the large boards are the regulator boards, 50x70mm, and came to 9E (about 13$) per board.
The small ones that you see in the picture are bridge-pcbs for the high voltage high current Schottky-diodes with ultra-low forward voltage - discussed here . With these little pcbs you can build a full bridge rectifier using 4 of these Schottky-diodes and I will offer a small number of them here.
If you're interested in the small Schottky-bridge pcbs, they're 25x25mm, drop me an email!
The regulator boards, however, are all gone.
Have fun, Hannes
High Octane phono preamp Wiki
Old 20th August 2008, 02:36 PM   #33
jackh is offline jackh  United States
Received boards from Hannes
I also got diode info from this thread
Old 19th September 2012, 03:51 PM   #34
h_a's Avatar
I just found 4 of these regulator boards that I still had somewhere!
In case somebody would like them, just let me know!
Old 6th June 2013, 10:58 AM   #35
fonzobrown is offline fonzobrown
Ciao Hannes! finally the parcel with your board is here
I just want to thank you 'cause your're really a kind guy to deal with
See you next
Roberto
Old 6th June 2013, 02:26 PM   #36
h_a's Avatar
Thanks for your kind words!!
I mailed you all the details
Old 15th July 2016, 08:32 PM   #37
Ruzam is offline Ruzam
Originally Posted by h_a View Post
Schematic
Please note that caps on the regulated side are necessary and that I did not provide space on the pcb for them. They should be mounted on the amp board anyway, so that they're close to the load.
Hi there, I am currently looking at the LT1033 regulator for negative voltage regulation but it is a bit pricey now that it's discontinued.
However here you have two positive regulators. I am confused. Is CONN4 outputting a negative voltage, if so how is that doing that from CONN"?
From CONN2 is '1' outputting a positive or negative voltage?
Thanks for any help.
Interest in dual regulator LT1083 pcbs?Hide this!Advertise here!
LT1083/LT1084 Regulator uhcmos Swap Meet 18 6th August 2008 05:46 PM
LT1083/LT1084 Regulator uhcmos Solid State 2 9th June 2008 06:51 PM
LT1083/LT1084 Regulator uhc-mos Swap Meet 1 30th May 2008 10:57 AM
LT1083 PS-regulator for class A amps bogdan_borko Pass Labs 26 15th August 2007 07:02 PM
IC Voltage regulator (LT1083) problem trombone Power Supplies 5 10th March 2006 02:28 PM
