Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 22nd February 2008, 11:32 AM   #101
chalo is offline chalo  Argentina
sorry, i could not open the BOM before as my pdf didnīt work.
Though are those drivers good?
Thanks, and regards!
Old 22nd February 2008, 11:59 AM   #102
tinitus is online now tinitus  Europe
My trafos are measured unloaded at 2x38Vac(2kwatt) fore output and 2x43Vac fore input...hope thats ok
Old 22nd February 2008, 03:00 PM   #103
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
chalo;
jan.
Can I use 2sc4793/2sa1837 in place of mjeīs, as long as
2sc5200/2sa1943 for the output?
And what other options of opamp would work here?
opa 2134?
with the rails voltage you suggested what is the expected output?
Regarding other transistors please check pin layout, Wattage and SOA (please understand that my time is limited and that I can't check parameters for all who want's to use other devices).
Pin layout for both the drivers and output devices are: B C E
The 42VDC version provides app. 200W into 4 Ohms and 100 into 8 Ohms.
For the 50VDC version the numbers are 135W/8 and 270/4.
Vp^2/(2*RL) e.g. = 40^2/(2x8) = 100 Wrms
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 22nd February 2008, 03:15 PM   #104
Jan Dupont's Avatar
tinitus
If you intend to benefit from the 2kwatt output trafo you need to ad many extra pairs of output devices and use 1 Ohm speakers
Your trafos gives you app. 54VDC for the input section and 60VDC for the output section. Normally you would use higher Voltage for the input section (VAS) than for the output stage to compensate for the Vbe loss (3x0.7V) in the predrivers/drivers/output devices.
Note that your output could never be higher than the Voltage at your VAS stage (54VDC minus some losses).
Forgot: Your trafos can do the job
Old 22nd February 2008, 03:45 PM   #105
Originally posted by ACD
tinitus
I think you might have misunderstood, and reversed data, or I may not have been very clear...it is actually like you suggest, 60VDC fore input and 54VDC fore output...so its all fine I guess
Old 22nd February 2008, 03:46 PM   #106
jimmy.e is offline jimmy.e  Sweden
I would be interested in 10 boards.
Iam pretty new to this board, so i cant pm u my information. Iam mailing it instead.
Old 22nd February 2008, 03:51 PM   #107
Jan Dupont's Avatar
tinitus
Old 22nd February 2008, 06:27 PM   #108
Send a message via Yahoo to ANTHONY2181
Hi Jan,
I added 4 boards to the Wikki.
Anthony
Old 22nd February 2008, 09:00 PM   #109
Jan - Typically what bias level do you use with the Lynx? I am interested in using several boards for a home theater system and want something which is not a room heater. There are all sorts of very good class A designs, but they are not attractive in this sort of application. Also have you tried using an inexpensive op amp such as a TL071 or an NE5532 in place of the OPA device? Regards, HK
Old 22nd February 2008, 10:05 PM   #110
Jan - I should have written 5534 and not 5532. Regards, HK
Page generated in 0.11900 seconds (78.15% PHP - 21.85% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
