I have today sent a confirmation email to those I have email contact information on.
If you have ordered boards in the Wiki, and haven't received this email from me, then I'm missing your email address in my log.
If so, then please email me so I can contact you when the Group Buy ends.
Thanks for the interest
I may change from 4 to 6 PCB's as soon as the total count gets 98ACD said:Seems that we only miss 10 pcb's in the group buy to reach 100
Go ahead and change your order, I just made it 98.
Several has asked me question regarding Rail Voltages for this LYNX Amp.
I can inform you that I run my Amps on +/-42 to +/-50 VDC (toroid 2x30 to 2x35 VAC, 300W per PCB).
I know many who uses higher voltages (with the onboard Current Limiting circuit disconnected), however I see no point in that as the SOA (Safe Operating Area) for the output devices then is easily reached
And last a warning!
Many have over the years emailed me with the same problem;
The driver transistors MJE15032/MJE15033 blows up when powered up first time....
I did also experience this in the beginning, until I realised that my MJE's was fakes !!! Trashed them all!
The original MJE's will NOT blow up! These transistors are perfect for this job, and used in many designs.
And last a warning!
gary s said:Hi Jan
Good on you Jan. Keep up the good work.
Count is now up to 107 boards, anyone not signed up yet should get in as this is a very rock solid design.
Gary..
OBS.
The WIKI totals 105 right now! Ragnwald and WJH are not on the WIKI list. Wonder what WIKI they signed up in.
If you are right and those two guys signed up, the total should be 111? Just wondering....
Edit. Oh, WJH just made it to the list, so total is now 107.
- Group Buys
- LYNX Power Amp PCB Group Buy interest
