Group Buys Members group buys
Jens Rasmussen Leach clone group buy
Old 5th August 2012, 08:47 AM   #1451
tryonziess is offline tryonziess  United States
Tony, you would need to discuss this with Jens and Andrew. I believe this discussion came about in the initial design of the 6 output boards. I became involved with this project as a means to acquire boards for my own builds.
I too have gotten into the tube amp area, though rather slowly, acquiring everything for a nice GU-50 amp. I have yet to get the pcb's layed out. The rest is pretty much done. I have hand wound the transformers and cut out most of the material for the chassis/case. Winding these transformers is a very tedious job. If you go to the christl ludwig site in Denmark or Germany you can see the base of my design. This guy is quite good. Just google 160 watt tube amp. Very nice. He has done all of his homework and much more.
Tad
Old 5th August 2012, 09:14 AM   #1452
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
thanks Tad, i can find my way around Leach issues....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 6th August 2012, 07:01 PM   #1453
R.I.P.
D.Self, Blameless, Distortion Seven, NFB take off point.
regards Andrew T.
Old 6th August 2012, 10:43 PM   #1454
soltari_knight is offline soltari_knight  United States
soltari_knight's Avatar
Hey Tony, I remember back then you mentioned you did some work on the double barrel. Did you have any luck on that?
Old 18th August 2012, 03:20 PM   #1455
Junie is offline Junie  Philippines
Originally Posted by ipolyakov View Post
I have two boards for sale. if you are interested, please contact me at ipolykov at pacbell.net.
Thanks,
Igor
Hi Igor,
I got it, thanks a lot.
remarkable quality boards and professionally made.
BR,
Junie
Old 19th August 2012, 12:41 AM   #1456
TonyTecson's Avatar
some guy in Manila was able to build 4 channels, unfortunately his hardrive crashed and lost all the files.....
Old 19th August 2012, 05:21 AM   #1457
Default trimpot
Sir Tony good monirng!
Is it possible to use a 5K trimpot instaead of 4.7K?
Old 19th August 2012, 05:24 AM   #1458
TonyTecson's Avatar
yes....
Old 19th August 2012, 05:47 AM   #1459
Thanks.
Old 19th August 2012, 09:42 AM   #1460
R.I.P.
The tolerances on trimpots are often +-10% and +-20%.
Effectively 5k and 4k7 are the same thing.
regards Andrew T.
Jens Rasmussen Leach clone group buyHide this!Advertise here!
WTB:2 boards from Jens Rasmussen Leach clone group buy mpmarino Swap Meet 0 12th January 2009 11:53 AM
