Old 10th April 2007, 10:08 PM   #1
Mayday is offline Mayday  Sweden
Send a message via MSN to Mayday
Question What to build with these...
I'm going to use these Philips AD 706 6,5" Fullrange elements, quite modified.
Measured data:
8 ohms
Q=0.7
Vas= 17 liter (0,6cu.ft)
Sensitivity = 90dB
Fs = 70Hz
supposed to roll off at 18khz
They are dusty and dirty but in perfekt shape.
I'm leaning towards horns or dipoles, what du you guys think?
The more you learn, the more you realize how little you know...
Old 10th April 2007, 10:17 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
depending of room and space you have;
try them on temp baffles ,then- if you think they deserve that,build bigger baffles with 15" bass helper and helper tweet ( if needed) ;
look at "beyond the ariel " thread
and- google for "lampizator" , then check his speaker pages
if you have no room for OB, find this :
http://www.sonido.hu/adat_pdf/DIY/DIY-MH-14-light3.pdf
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
Old 10th April 2007, 10:24 PM   #3
The speakers I'm building are for my brothers daughter, it's her first stereo I'm putting together. For ampification I'll use LM3886 chipamp.
My brothers budget for this build doesn't allow for further drivers.
Do I understand you correct that you suggest open baffle design?
I use that myself with Dayton 15" IB, Seas P17RCY and B&G NEO8.
Old 10th April 2007, 10:32 PM   #4
That horn design you linked to looks intresting, do you think this driver is suitable for that?
Old 10th April 2007, 11:46 PM   #5
Zen Mod's Avatar
even if not completely adequate - and you can find out only building it- it will be miles ahead any boxie box you can made for it.
all that - if that driver is anywhere near old good AD Philips series.
anyway-little girl will be thrilled with completely unique spks
now-serious- good horn construction are way more forgivable to various driver than closed or BR boxes.
at least for my limited knowledge
Old 10th April 2007, 11:48 PM   #6
These drivers are Philips AD 706 but modified.
Thanks for the advice that horn looks really intresting.
Old 11th April 2007, 12:54 PM   #7
After talking to the girl that is going to use these speakers, she was leaning towards OB design, since she likes my dipoles.
Question is, can these drivers alone on an OB reach adequate listening volume? Not Very loud, just enough for everyday use in an apartement.
Old 11th April 2007, 02:50 PM   #8
Geoff H is offline Geoff H  Australia
Mayday, would you believe I am currently working on some 6" Panasonics, with a Fs of 76Hz, on little OBs. The idea was to extract as much sound from these as possible.
OK, they won't shake the floor, but do go quite low for what they are.
The size of the baffle is 460mm high, 300 wide, with sides, 165mm at the lower end, tapering to 118mm at the top, (to be reduced) and a full width top shelf of 76mm.
All made from recycled MDF. I started with just the baffle. Played with different sized wings, to bring the bass up. I have lost a bit of sound stage, that's why I am trimming down the sides. in my case, a bass helper will fix the bottom octave or two.
I would give the back of the cone 1 coat of PVA, the whizzer 1 coat, front and back, the area behind the whizzer a coat, then 1 more coat over all the front of the main cone.
If you have some bitumen paint/sealer, some around the perimeter of the whizzer kills of some edge resonance. A light coat on the roll surround will raise the Fs a bit, which is OK on the small baffle. Mine started at 70Hz.
She will be pleased. I have passed on a few tweaking experiments to younger folk.
Geoff.
Edit: Hey Zen, they are old Philips. Not old enough for alnico though.
Old 11th April 2007, 02:58 PM   #9
Geoff.
I'm thinking of a baffle size of about 1,5x1m or there around.
A few questions; what's PVA, and what's wizzer?
Old 11th April 2007, 03:30 PM   #10
PVA = Poly Vinyl Acetate = white wood working glue. Others use Puzzlecoat and or Damar. Dave at Planet 10's a guru in that area.
Whizzer = the little cone or tweeter cone.
Baffle size. Bigger is better.
I want to try and build my own DAC gareth Digital Line Level 3 3rd July 2009 04:20 PM
ZV9 build ingi Pass Labs 8 6th August 2006 03:40 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
Page generated in 0.11418 seconds (86.90% PHP - 13.10% MySQL) with 11 queries
