Old 22nd April 2007, 11:16 AM   #41
Mayday is offline Mayday  Sweden
Does damar need to be thinned? I'm guessing I should apply it as thin as I can?
The more you learn, the more you realize how little you know...
Mayday DIY blogg
Old 23rd April 2007, 08:34 AM   #42
frugal-phile(tm)
planet10's Avatar
Originally posted by Zen Mod
[ll that - if that driver is anywhere near old good AD Philips series.
I'm in late to this thread .... hope i'm not repeating something that is said in the next 4 pages...
What vinatge is that unit... except for the whizzer it doesn't look much like any of the Philips i'm used to seeing, but as Zen Mod says if it is anything like the ones from 70s, early 80s it should do well on an OB...
what wood did you use for the phase plugs?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd April 2007, 08:41 AM   #43
I didn't make the phase plugs, they were made by previous owner.
I believe they are from the 70 - 80's hard to tell because they are in such good condition. Model is AD 706.
Mayday DIY blogg
Old 23rd April 2007, 08:47 AM   #44
frugal-phile(tm)
planet10's Avatar
The stuff i buy at the art store is already mixed up... i've been using it on whizzers to good effect, but i hesitate to use it on the main cone -- i prefer to use puzzlecoat (a PVA that remains a bit more flexible than wood glue)... http://www.t-linespeakers.org/design/tweeks.html
i thin it until it is runny, and on a full range use 2 (or maybe 3) coats on the front-- using almost as little as possible. If i wwant to significantly stiffen the cone, i'll also do the back... you end up with a poor mans sandwich cone -- but in a full-range this isn't always the best thing, since the cone needs to flex to get decent HF performance. Too much and you can turn a FR into a midbass.
You can't really tell that the cone has been puzzlecoated in this one, but you can see how the damar has changed the colour of the whizzer (it used to match the surround)
Old 23rd April 2007, 09:02 AM   #45
I bouht my damar in an artstore. I'll just coat the wizzers to begin with.
Mayday DIY blogg
Old 23rd April 2007, 09:03 AM   #46
frugal-phile(tm)
planet10's Avatar
Model is AD 706
I've run across lots of AD7060 (with octanganal basket and brown main cones) but not these...
dave
Old 23rd April 2007, 09:07 AM   #47
A bit of the label has been torn of the box, all I can read is Philips AD 706 60-18000hz 25W
Mayday DIY blogg
I want to try and build my own DAC gareth Digital Line Level 3 3rd July 2009 03:20 PM
ZV9 build ingi Pass Labs 8 6th August 2006 02:40 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Page generated in 0.09465 seconds (80.09% PHP - 19.91% MySQL) with 11 queries
