Old 6th April 2007, 03:04 AM   #1
OzMikeH is offline OzMikeH  Australia
Default Help, Foxtex Fe207E FE206E hole size
My FE207E drivers are taking a long time to get here, I want to cut the holes in my cabinets for them.
The Foxtex literature says 185mm cutout is required. Can someone measure a driver and verify this for me please?
I had a bad experience with a JBL driver that stated a hole size on the literature that was actually 7mm bigger than the required hole. I had to start again with the front baffle for that one.
Has anyone made a cabinet with these drivers and cut the hole at 185mm instead of making it to fit the driver directly?
Can I trust the fostex datasheet?
Old 6th April 2007, 05:07 AM   #2
Anyone...?
<waves router in the air eagerly>
Old 6th April 2007, 05:21 AM   #3
ttan98 is offline ttan98  Australia
"My FE207E drivers are taking a long time to get here"
there is a local distributor in Australia... the name is
http://www.majormusic.com.au/
cheers happy lisening..
Old 6th April 2007, 07:34 AM   #4
Yep, they are who I used.
They were very good, the speakers were dispatched from Sydney on Monday. they didnt make it here by yesterday so I wont see any until at least tuesday, probably wednesday.
I just want to make sure I dont cut too big (or too small) hole in my cabinets. I want to start sanding and painting them in the next few days so I'd like to cut the holes before the drivers arrive.
Old 6th April 2007, 10:04 AM   #5
Scottmoose's Avatar
I don't remember needing to make alterations to any of mine, despite using the driver information. Fostex designed them, so their measurements tend to be quite good...
Old 6th April 2007, 11:51 AM   #6
My drivers arrived, Horay!
I didn't expect that on Good Friday (A public holiday here)
183mm with a very slight chamfer
impressive build quality. I haven't used Fostex drivers before.
the screws that come with them look pretty cheap though, I won't be using those.
FE206E v. FE207E bass reflex DavidLewis2 Full Range 41 23rd May 2009 01:11 AM
Fostex 206e baffle hole size ljk11 Full Range 2 3rd January 2009 10:01 PM
bass matrix hole size....does it matter i4gotmyid Multi-Way 1 5th October 2007 04:27 PM
PCB Hole Size ptah Parts 10 30th November 2006 02:51 AM
Fostex FE207e vs. FE206e Kashmire Full Range 0 15th January 2004 05:18 PM
Page generated in 0.08478 seconds (74.46% PHP - 25.54% MySQL) with 10 queries
