AJ-Horn & BiB - ar some BiB "parabolic"?
Old 6th April 2007, 12:43 AM   #1
freddi is offline freddi  United States
freddi's Avatar
Default AJ-Horn & BiB - ar some BiB "parabolic"?
I didn't go through all the possible flares, but "parabolic" seemed about right in vessel air volume (conical only gave 127l) and simulation with At ~0 and 35 inches driver offset with 206 looks plausable (?) do any AJ users have comments?
a 206E parameter sim & comparison to RCA-Fan's k-slot which is the same volume cabinet but quite a bit different in path, etc.
http://fullrangedriver.com/forum/viewtopic.php?id=1600
Old 6th April 2007, 10:16 AM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
No, not in flare, they're technically linear, although they behave in a very similar way to conical expansion. Having said that, I'm looking at possible different flares that can be created by some minor changes, and quasi-parabolic is one of these. Looks like it could offer something of interest anyway. The Vb of TC's original BIB is the same as the back chamber of a 24Hz hypex horn BTW. Or so I gather -I haven't checked it myself. I somehow doubt that Terry intended that, but an interesting piece of trivia for you.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 6th April 2007, 02:01 PM   #3
freddi's Avatar
with AJ and 206 BiB - it gets down to only one flare description out of seven giving the right overall horn bulk so that may be one clue on how to (hopefully) make it best fit existing horn/etc, ---AJ will design new horn and give contour --- might look at a few more BiB and see how results compare to Zilla's page of graphs.
AJ horn volume output for 206 BiB with AT = 0.001 sq.cm. Driver position =0.89M, L=4.42M, h=20.78 cm, b = 41.56 cm, dl=0.2M
conical=127.28 l, exponential = 27.93 l, parabolic = 190.86 l, hyperbolic = 25.35 l, octohyperbolic = 17.89 l, geometric = 0.01 l, tractrix = 31.56 l
Old 6th April 2007, 03:09 PM   #4
freddi's Avatar
yep - looks like "parabolic" is it out of available choices for BIB and AJ-Horn. How does 166 BiB stack up dynamically vs 206 BiB?
Zilla's FE166 is 97.7925l, AJ under "parabolic" gives 97.78l and the following simulation comparison
AJ-sim using parabolic
http://img232.imageshack.us/img232/6...ebibrawnh5.jpg
Zilla sim
http://img232.imageshack.us/img232/1...66grapheb9.gif
AJ-Horn & BiB - ar some BiB "parabolic"?Hide this!Advertise here!
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Grill Material for Stan White "Curled" Horn Reproduction rlabomb Multi-Way 0 26th May 2008 02:24 PM
are bandpass subs passe compare to "horn-sub"? freddi Subwoofers 9 30th September 2007 07:54 PM
Data of Isophon DKT11 "Exponential-Hochtonstraler", treble horn peranders Multi-Way 3 10th December 2002 08:13 AM
