Old 5th April 2007, 09:29 PM   #11
chrisb is offline chrisb  Canada
If compact "desk top/bookshelf" size factor is not critical, you might want to look at the Metronome. For a monopole design, these will be pretty shallow ( 6" or less).
The Metronome
Another very decent sounding enclosure design for the FE127 is the
New Fonken pair is born.
Old 5th April 2007, 10:47 PM   #12
Consul is offline Consul  United States
Send a message via ICQ to Consul Send a message via AIM to Consul
There's also the Cyburgs Monitor:
Cyburgs-Monitor for CSS FR125S
I'm still leaning toward the FE167E/Supertweeter combo, to tell the truth. Maybe I can cut my woodworking teeth enough on those to take on the Ariels as a pair of mains later on.
Old 6th April 2007, 01:13 AM   #13
Hello Consol,
PM me I will give you my phone number. I think you will like the FE167's I designed.
I also built some FE127's for a friend, we have yet to assemble the cabinets. They are 10L tuned to 70Hz. These would be another option (less cost) as well. I feel you may not want to use Ft17H with the FE127's they have more of a high end peak and no dips like the FE167 has at 15kHz.
The FE167 with Ft17H project cost me around ~$550.00 to build including wood and electronics. TheFE127's cost around ~$260.00 including electronics (give or take $50.00 for each project depending on what electronics you want to use). I used exspensive 1% mills resistors and Erse iron core inductors for BSC.
I used 18mm marine grade baltic birch plywood for both projects. I also used sonic barrier to line the cabinets from parts express (I used the 3/4" version).
Out Here,
Robert W.
Old 6th April 2007, 01:24 AM   #14
I can't seem to PM you using this board. I'll go ahead and PM you on the PSW board instead.
Thank you for bring willing to help me out!
Old 8th April 2007, 04:59 PM   #15
I just wanted to bump this up to make sure rfenergy sees it. Also, if anyone knows how to PM someone on this board, I'd greatly appreciate knowing how, as I can't seem to figure it out. Thank you!
Old 8th April 2007, 07:40 PM   #16
Hello Consul,
I tried to PM you and on this board and it said you did not allow PM's. So check you user preferences here and see if everything is set correctly.
I did get your PM from pro sound web. I have your number. I will call you this week for sure, doing the holiday thing today.
Out Here,
Robert
Old 8th April 2007, 09:17 PM   #17
Really? I don't remember disabling them, but I'll certainly fix that. Thank you, and thank you for your help!
EDIT: My options screen said I had PM's turned on, but I went ahead, shut them off, then turned them back on, to see if that helped.
SMPS inverter complete design and description drwaseerwp Power Supplies 0 19th May 2008 07:49 PM
Tl Basic Design Question. christophorus Multi-Way 37 29th November 2004 05:12 PM
Basic box design. MWP Multi-Way 2 17th November 2003 04:19 PM
Basic Q on tube amp design mrstone Tubes / Valves 4 20th August 2003 11:22 PM
New site design! Jason Everything Else 2 28th January 2001 04:35 PM
Page generated in 0.08766 seconds (85.97% PHP - 14.03% MySQL) with 10 queries
