Old 31st March 2007, 08:12 PM   #11
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
My point was trying to _understand_ the issues involved when designing a narrow vs wide baffle and using one vs. two woofers.
I'm with you now! Well, it is an interesting subject for sure! I'm doing other things at present but may get back to OB building later in the year.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 2nd April 2007, 11:25 PM   #12
Geoff H is offline Geoff H  Australia
Hi Florian. As for baffle width, wide versus narrow, I think each has its merits. Wider gives better bass response, narrow better midrange.
I am not a great fan of sims, however The Edge may give you some insight. You don't have to stick with rectangles either. I ended up with this test baffle, used to tweak drivers.
The biggest problem we face is getting deep bass from a finite baffle. What we need is a high pass acoustic filter to go behind the driver.
Adding a woofer improves the situ for a number of reasons. The W/R purists frown on the idea for valid reasons. I am of the thinking that an AP enclosure for under 150 Hz or so, is the way to go, for it's transient and phase response. The W/R unit should be unfiltered, the woofer crossed over such that it fills the hole, with minimum phase shift.
Some will frown on that. It's a compromise that this W/R OB fan can accept.
Geoff.
chr-70 designs. castlesteve Full Range 17 1st June 2011 09:27 AM
G&S Designs fongman Car Audio 13 25th March 2010 04:33 AM
QSC designs clovi_kate Solid State 1 22nd March 2007 09:49 AM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
Page generated in 0.08261 seconds (71.93% PHP - 28.07% MySQL) with 11 queries
