#41 |
Agreed. GM's will ultimately be the more capable enclosure (bigger is better) once tweaked to your taste / room requirements. OTOH, mine will be closer to a 'plug & play' box in a smaller space, so as ever, YMMV. Frankly, if you don't mind juggling the vent dimensions a bit to tune to your room, then I'd build Greg's.
#42 |
Account Disabled
My place is a little bit small, 10"x25" so maybe I must go with Scott's? What do you say?
The difference isn't to big though............. GM's isn't too much bigger ![]() Just in case, I'll build GM's, the only tuning is the port's length? |
#43 |
Right. Increase the length to roll it off if you feel the bass is a little heavy / boomy due to it overloading your space. 10ft x 25ft isn't what I'd call 'small' though -by UK standards that's a pretty decent size.
#44 |
Account Disabled
Due to the new thread that has been posted about Hemp's "non pure Hemp" construction I'm thinking not to buy a Hemp driver ,yet. I'll wait until the company will standarize their products......
So what about a wide baffle MLTL with FE207? Or MJK's MLTL? I need bass that's why I have stucked with an 8". If you believe that I'll have enough bass with a 6.5" and better mids than the 207, not a problem..... please help! I CAN"T DECIDE WHAT TO BUILD ![]() Scott, Do you believe that my room has a pretty decent size for a BIB? |
#45 |
Heck yes! You've a choice really -6 1/2in or 8in units, though I'd limit the height of the cabinet in both cases to 70in or you might things a little lively. And they'll cream any MLTL on dynamics, which FR drivers can always use a helping hand with.
FWIW, I'd probably go with the FE168ESigma. Use the Sl dimensions I posted on the Zilla site, but increase line length to 138in (70 in tall cabinet) and Zdriver to 30in. Job done. I love the FF165K too, but it's better suited to smaller rooms, so the Sigma would be my choice of 6 1/2in driver for your environment. Alternatively, if you want an 8in driver, the FE207E, again same height & driver position as mentioned above, with the Sl dimension off the Zilla site should be OK. |
#46 |
Greets!
So many choices, so little time. If you have a closet you have a big enough space since a pipe horn has gobs of tuning flexibility, though obviously you reach a point of diminishing returns WRT usable Fp. Anyway, ideally you'll put them in the corners of a 10 ft wall and sit ~15.45 ft away. With no major room gain kicking in until the 20s, I'd stick with the 8", though all things considered, one of the HE versions seems a better choice. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#47 |
Account Disabled
Build a Hemp in a BIB was my first choice. But when I realize that I need a cab around 20" deep (minimum) I thought that they're too big for my room.
Also, the distance btw the drivers will be around 5.5-6ft. I'd like to place them as far as possible.......... Now my ME2 (ariel) are at 6.6ft. |
#48 |
Well, the hempster might be a trifle large, aesthetically speaking. That's a taste thing though. OTOH, the Fostex 8in range don't need such a big enclosure, so the 206/7 or even the 208ESigma (with additional supertweeter as it's a WR rather than FR unit) should suit you nicely & they've loads of excursion too. Fostex have not built up their formidable reputation by building poor drivers.
#49 |
Account Disabled
Ok what do you say to go with the FE207? (or the 206? - which arethe differences?)Not a too big BIB and a good choice for an 8in. Also if I can live with them in my room I can go with bigger ones in the future. Hemp's are good as said but with what is going on right now with the cone materials I'm a little bit afraid to buy them. I'll wait for a Tone Tuby........... ![]() P.S.: We got a little bit out of topic in this thread. I'll post new messages in the BIG TC's BIB thread................ Sorry to the author |
#50 |
Greets!
Well, I recommended a HE 8" as a compromise between LF output and the 'magic' of a smaller driver's mids/HF, so for Fostex there's only the FE206E, FE206ES-R, FE208ES AFAIK and I don't have any personal experience with these, so you'll have to rely on others for mid/HF performance opinions. GM
| FS HempTone 8"FR | nvrgdenuf | Swap Meet | 0 | 11th November 2008 05:43 PM |
| Hemptone FR 5" | chuck55 | Full Range | 30 | 9th December 2007 02:42 AM |
| 4"x8" Port = two 4"x4" Ports for MLTL??? More Complex??? | OTMOPO3OK | Full Range | 2 | 17th January 2005 03:58 PM |
| Page generated in 0.11389 seconds (75.71% PHP - 24.29% MySQL) with 11 queries |
