Re: lousymusician
Originally posted by ttan98
You have both Hemp and Fostex, how do they compare to each other?
Can you give us some descriptions of the sound quality of each unit? eg, differences and similarity
I believe Hemp is a little more expensive right, if it is better then it is ok, otherwise is it worth buying?
Sorry, I don't own nor have I even heard the Fostexes.
I find that for my taste the Hemp needs a little taming up top, though others differ. They currently have a 1 mH inductor||9.5 ohm resistor network, but I need to do a little more work on that. I guess it depends on how well you get along with a whizzer.
That said, they are dynamic, punchy and detailed, and make pretty satisfying bass (at least in my smallish room). They can work fine in a pretty simple BR box, though the Metronome is a little cleaner sounding. I had them hooked up to my Panasonic HT receiver for a few weeks, but that combination never jelled well. Things are much better back in the den, with a Curcio-modified ST70 (strapped into triode mode).
Were I to start over, I might be tempted to save a few $$ and try the FF165K's instead.
The difference between theory and practice is that in theory there is no difference between theory and practice, but in practice there is.
