Old 25th March 2007, 12:10 AM   #1
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Default New 'peekas [Fostex Sig's]
Can't wait to hear them, I'm building some open baffles for them tomorrow so I can burn them in and just get an idea for how they sound.
Does anyone else have Sigs with the tinsel leads attached to the bottom of the cone with that white goopy stuff? I hadn't seen that before, wondering if that's a design change or something from Fostex.
Jim J.
Old 25th March 2007, 12:17 AM   #2
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
They sure look gorgeous. Is that a normal spider? It doesn't look it in the photos.
Brian
Old 25th March 2007, 03:43 AM   #3
Glowbug's Avatar
Yeah, the spider definitely looks different than the normal concentric ones I'm used to seeing.
Does anyone with these know how much break-in time to expect? I've heard they take hundreds of hours to really come into their own...true?
Jim J.
Old 25th March 2007, 07:56 PM   #4
Colescuttle's Avatar
Send a message via Yahoo to Colescuttle
Default Speeding up Fostex break-in time.
When originally experimenting with Fostex drivers in BLHs I got tired of waiting to tune the horn while the bass came fully on line. My solution is not novel, by any means, but it works better than anything else I've tried and I treat every Fostex driver right out of the box.
Get some really thin silicone oil. I now use 1.5 wt Airsoft-Innovations stuff that's sold as a paintball magazine lubricant by Airsplat (www.airsplat.com). Then get a disposable insulin syringe from your local pharmacy; one with the smallest bore needle they have.
Draw a small amount of oil into the syringe, and holding the driver with the cone facing upwards, and, keeping the syringe with the point of the needle above the horizontal (the stuff is so thin it will easily leak otherwise), put ONE drop of oil on the spider in each of the openings in the basket. Try to deposit the drop of oil midway between the outer edge of the spider and the former. Even with a very small bore needle it's hard to consistently dispense one drop, so practice on something else before you treat the spider.
Then store the driver with the cone facing upward. Within several days the oil will have been equally distributed in the spider fabric by capillary action (you'll know because the color of the spider will darken uniformly). If for some reason you don't see uniform darkening of the fabric after several days, deposit ONE drop of oil in the center of any light patches.
Then break in the driver with a break-in track for a couple of days, which is much less of a noisome bother if you do it before mounting the driver in your cabinet.
George
Old 26th March 2007, 08:43 AM   #5
planet10's Avatar
The spider is shaped much like the surround (which is a brilliant design)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
fostex 208ez and fostex ft17 h good kombo? almightybozo Full Range 1 24th September 2010 07:00 PM
FOSTEX FE126 in Fostex BR Enclosure nafunga Full Range 3 29th July 2008 08:21 PM
WTB: a pair of Visaton B200 or Fostex F108ES or Fostex FE126e or Jordan JS92S Rafal Swap Meet 0 10th November 2006 02:35 PM
Fostex BLH boonedog Full Range 1 23rd March 2005 09:39 PM
Fostex FE 206 E in ML TL Again levon Full Range 0 16th April 2004 09:02 AM
Page generated in 0.09905 seconds (73.34% PHP - 26.66% MySQL) with 10 queries
