#131 |
frugal-phile(tm)
Andrew,
I'll get back on the other questions, but i do have DXFs of an iteration of Chad's drawings and have a CAD drawing started -- time for me to finish it. Our A126 went off to a friend's house for use as "computer" speakers with his new 27" iMac. He has a small room that is particularily synergistic. Performance is staggering. His are the green drivers with the new underpainting trick i've recently learned (picture doesn't do them justice). dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#132 | |
Based on our own and other anecdotal reports, you'd likely be more than happy with which ever version of the FE126E you find in the A126 - but FWIW, I think the polka dots are definitely worthwhile
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#133 |
I was just thinking, what about using something like the ikea wooden bowl trick as the SB, for example as posted here: Ikea bowl speaker drivers
#134 | |
frugal-phile(tm)
dave
#135 | |||||||||||
frugal-phile(tm)
The best shape is likely a the teardrop shape as exemplified by the midrange pods in the B&W Natilus 800s or the FujitsuTENs. ![]() As to shape, if you look at Page 23 of Olson, you can see that the shape that Ron presents is a really good compromise between best & buildable. ![]() Quote:
For purely aesthetic reasons, I'm considering adding 3 more layers of wood behind the baffle, to make it look more like a "bubble" then just a baffle. [/quote] Rounding the bends[/quote] Ron thot this was a good idea, but it does extend the HF bandwidth of the horn, which in things like the Olson-Nagaoka style horns degrades performance, Quote:
We like to use removable cups so as to maximize future versatility. MPO is that posts should have as little metal in them as possible (ie plastic nuts instead of the big metal ones. The ones Mark Audio is working on look good (unless, like us, you use double bananas to make comparison swapping easy). Bare wire is the sonically best ternination, the best trick is to use binding posts simply to clamp the bare wire from the drivers to the bare wire from the amp. Quote:
dave
#136 |
Hi A126 builders. I just wanted to share my experience with this speaker. It is a tricky speaker to build and here are some lessons learnt:
//Anders |
#137 |
Thanks Anders, this is helpful - this design has attracted my attention before. I particularly like your thoughts on the ambience tweeter, I'm thinking it may have application to some of my existing bass-reflex speakers.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| Page generated in 0.13969 seconds (77.95% PHP - 22.05% MySQL) with 11 queries |
