#11 |
You're giving away your secrets here Ron...
Best Scott |
#12 | |
Several were based on radiation physics many on acoustics some on ultrasonics and even some on explosions inside of pressure vessels. Stir in some of MKs math, some advice from GM have a young computer savy guy write the program ( tweak it forever) and you get realistic answers. ron (A quote from the Fly: all i am is a systems management man, i rely on the work from people much more brilliant than me"). |
#13 |
Hi Ron,
"Nonsence" test it, who thinks he can use a horn more than 3 oktave didn´t understand something. Look e.g. the TRUMPET testet and listening with 3 driver, the driver are so different but more ore less the same measurement, the horn dominats the driver, one has a 0,8 Qts one 0,21 it worked. If you make a lot of tests with different driver in the same horn and simulation a few you will find a difference of only 1-2 dB, try it. BASSTUBA e.g Manger Tannoy, Dynaudio. Expo: I have the formula in mind, so it´s easy, if you look my flares, spec. the ALPHORN you see a different funnel constante the last 70 cm. Give me a link for the measurement and Impedanz. Ron, if you the specialist, tell me the look of the system-membranmovement of SAXOPHON, TROMBONE,POSAUNE you would help me. Scottmouse: "I can't see a problem with a driver / horn working to 400Hz either if it's accounted for in the design come to that." How many construktions you´ve done and measurements, a good bass horn should shut up above 150 Hz, for PA it is not necessary, for HiFi a must, everything over 150 Hz direct, make the sound coloured like Lowther, Fostex horns. It must not happen if you use the right material for the first horn meter and the presschamber.
http://www.hm-moreart.de |
#14 |
How many? Probably around 25 or so various prototypes over the last couple of years, not including TLs, QWRs etc although obviously my own experience and knowledge, nay, wisdom, is far inferior to yours. I best abandon the double horn I had started to develop for this driver too, and another for the 208, so people will be able to use your designs as the only correct ones available. That'll teach me for believing GM, Ron, DaveD, Willam M. Leach, Tom Danly, the Fostex engineers, Terry Cain, Martin J. King, Dr B. Edgar, Olson, P.G.A.H. Voigt, Salmon etc. I really should have known better.
BTW -a minor point, but I think you'll find everything over ~73Hz is directional, not 150Hz. |
#15 |
Hello,
i agree with you. There are endless constructions out there, And I read and repect your people list, but e.g. Olson said ~1930 a HORN-SAT won´t work, it does, why? my "secret" is evident, the mouth membran distance an specially the low horn wall distance the last half of the horn is the key to make it workable. The last catalog like measurements from Visaton and Hobby HiFi shows with the B200/horn-sat, 98 dB +- 2 dB between 130 Hz-10000Hz, why they won´t publish it? 1 driver and an enclosure, wire thats it, the buiseness is not happy with such solutions. BTW: I meant with directly the mouth/listeners Is there no construction left to show us?
#16 |
You mean of my boxes? Wish I owned a digital camera. I can occasionally (very occasionally) borrow one, but it's usually not worth it. Most of my test cabinets are quick one-offs now, in chipboard, and experiments more than anything else with little effort to refine them -they're slapped together to check a specific feature, then binned as quickly as they've served their purpose.
There are some shots here, on my friend Steve's site though of my last major construction -mine are the double BVR style BLHs with the grey baffles: http://web.mac.com/scress1958/iWeb/S...ostexFest.html The Spawn designs including Harvey (the cabinet pictured on the above link), on www.frugal-horn.com are all collaborative efforts between myself and DaveD. That's what I've been doing mostly over the last year or so anyway. |
| FE168ESigma and Brines MLTL? | Idefixes | Full Range | 14 | 11th November 2006 08:36 AM |
| op amp recommendations | millwood | Solid State | 18 | 29th April 2003 12:49 PM |
| Page generated in 0.09718 seconds (74.71% PHP - 25.29% MySQL) with 11 queries |
