horn for two 3" driver
Old 20th March 2007, 12:23 PM   #1
hm is offline hm  Europe
hm's Avatar
Default horn for two 3" driver
Hello,
the listeners feedback is a cause to
make the plan for free download:
Trombone
best soundstage, cheap, small, enough SPL.
http://www.hm-moreart.de/24.htm
http://www.hm-moreart.de/88.htm
Old 20th March 2007, 01:02 PM   #2
kristleifur is offline kristleifur  Iceland
Definitely a design I'm curious to hear. Thanks!
Old 20th March 2007, 01:07 PM   #3
larkinrulez is offline larkinrulez  Germany
Yes...sounds very interesting...but it's a very complicated design and I ask myself....why?
Wouldn't it be more satisfying to take a 5" or 6" driver with a less comlicated enclosure?
But it's interesting...without a doubt!
Old 20th March 2007, 01:36 PM   #4
hm's Avatar
Default larkinrulez
look the Posaune
http://www.hm-moreart.de/25.htm
for 6,5 driver or Manger,
and the last plan page you find
a Posaune for 4" driver.
I built it after the Saxophon to hear what is
possible, the Trombone ist the smallest
fullrange horn with the cheapest price
and best soundstage I ever built.
2 x 4" page
Old 20th March 2007, 09:12 PM   #5
jzagaja is offline jzagaja  Poland
Is Trombone bipolar or dipolar? I was always fascinated by Manger Diskus.
Old 20th March 2007, 09:51 PM   #6
hm's Avatar
Bi-pol,
when you use the back driver invers change the pol.
You might get a better K2 in the bass and less HT effect
over ~1000 Hz (the end of the speaker invers) because
it stands near a wall, so HT reflection not wanted.
The distance between the driver is smaller than
between your ears, it is like one driver.
Old 20th March 2007, 11:17 PM   #7
Phergus_25 is offline Phergus_25  United States
Send a message via AIM to Phergus_25 Send a message via Yahoo to Phergus_25
Im sorry if this sounds ignorant, but so your basicaly using two speakers on two horns, per ch. One acting as a bass driver, the inverted one, and one acting above that and using the horns natural roll off as an X over?
Old 21st March 2007, 12:03 AM   #8
hm's Avatar
sorry,
there is much to tell, to much for my English.
look the single simulation of the membranmovement,
how looks the complet system movement?
I think the movement turn to an average, if so
its a kind of revolution, because everything gets better
by lower movement. and what happens at 40 Hz
the back driver moves more but it can because it
has a horn optimum, low movement
The single simulation shows nothing below 70 Hz
but you get 38 Hz.
There a some facts, like 4 horn mouth, 90°,
horn mouth distance, impedanz etc.
the alphorn instrument, to much to write.
I asked Mr. Dicks (DDD) and Mr. Keller (AER)
but no explanation is real found.
It happens
look also the Saxophon and Posaune
Old 21st March 2007, 07:11 PM   #9
hm's Avatar
The best bass explanation ist found:
Double horn explanation:
Building of organs
This phenomenon is used for a long time in the building of
organs:
With simultaneous employment of the 8-foot and the 51/3-foot,
which lie a Quinte over it, one hears the 16-foot, thus a Oktave
under the 8-foot. Thus a missing basic clay/tone can be simulated,
in which two clay/tone producers on the Oktave and the pure
Duodezime ring out at the same time to material the missing basic
clay/tone. With the organ will so e.g. 32 ' - registers saved, in which (preferably open) 16 ' - Labialregister with (covered) a 102/3' a Labialregister one combines.
Old 22nd March 2007, 10:36 AM   #10
hm's Avatar
not really, or ??
horn for two 3" driverHide this!Advertise here!
10" driver for Bass tower in Horn project angeloitacare Multi-Way 22 29th November 2007 01:10 PM
new horn for two 3" driver hm Full Range 2 22nd August 2006 07:58 PM
sensational horn for 3" driver hm Full Range 8 6th July 2006 10:07 AM
Looking for a ~40-300Hz Horn solution with a 15" Driver Bass-Depth Multi-Way 20 1st April 2006 04:19 PM
Will J-Low horn cab work with 8" driver shimmer Full Range 5 8th March 2005 05:47 PM
Copyright ©1999-2017 diyAudio
