Old 19th March 2007, 03:12 PM   #1
Default Speakers built into wall
This is my first post after having visited here over the last month or so.
I am owner building a new home and will be installing multi-room audio as well as a 5.1 / 7.1 system.
My partner likes music which is good so doesn't mind me spending some money on such things but she would like the system to be seen but not heard.
I am wondering if any of you know where I can find some DIY designs that would be suitable for building behind a false wall?
Most reviews I read say that the speakers work best up to 1m into the room but I would like them installed behind a wall with only a cloth grill revealing that a speaker is behind it.
I would like possibly a bi-amped config with tight bass and open mid/highs.
Budget I would say is around $500-$1000 Australian ($400-$800 US) per front tower speaker.
I would also like a matching 2 way design that would be suitable for installing in bulk heads (soffits).
I want system geared about 70% for music, and 30% for home theatre.
Any ideas would be much appreciated.
Craig.
Craig
Old 19th March 2007, 03:33 PM   #2
Fuling is online now Fuling  Sweden
Old 19th March 2007, 05:55 PM   #3
Buy Bang Olufsen and have it turned off!
Old 19th March 2007, 06:31 PM   #4
Colin is offline Colin  United Kingdom
Assuming you mean heard and not seen, there are a number of ways of doing this. Fullrange units can be mounted into wall cavities if the wall is solid enough. If it's a single, flat wall, you need to make sure the directional characteristics are suitable. In other words, do the drivers give a good stereo image if firing straight ahead. Some require significant toe in, in which case you will need to build a small sub-baffle out from the wall and have the bulk of the 'cabinet' hidden within the wall.
Another option is to use the wall for the bass units and use much smaller sats for lower-mid up.
Finally, you could fit the drivers into a wal between rooms and allow the room behind to act as the cabinet, close to a proper infinite baffle. You'll find more about that here
Old 19th March 2007, 08:20 PM   #5
Craig:
I completed the building of my home about 2 years ago. Since there was no basement, and I wanted a HT, the only place to put it was in the family room. There was no way I could clutter up the family room with speakers, subs, etc.
Here is what I used.
5 Jordan JX92s drivers in a simple 1 cubic foot box (if I remember correctly). The center, left and right channels were rececced in the walls between the studs and sheet rocked over, with a hole in the driver. I purchased some plastic grills at parts express and just covered the drivers. Did the same in the ceiling for the rears. The speakers are virtually invisable, and sound amazing. Using a 5-channel gainclone amp and a McIntosh MAC-3 processor that I picked up on Audiogon for a song.
I was lucky with the sub. the family room happended to have a stair well going up to the 2nd floor. I was able to recess that under the stairs, flush with the wall. I used a 15" sub from Adire audio.
All told, the system sound Awesome.
The Jordans are now expensive, around $200/each.
You could also do the same thing with the Creative Sounds FR125s
Also check the DC Audio Gold drivers (formally Babb).
good luck
Wall Speakers ? Bigun Full Range 14 20th January 2009 07:30 PM
Built differences between Guitar Speakers and PA Speakers? agadis PA Systems 7 24th September 2007 08:22 AM
So, why not in-wall speakers? wigginjs Multi-Way 4 20th August 2007 02:59 AM
In wall custom speakers CPopowski Multi-Way 4 19th March 2007 11:16 AM
In wall speakers bostarob Multi-Way 11 23rd June 2002 06:12 AM
Page generated in 0.08778 seconds (72.44% PHP - 27.56% MySQL) with 10 queries
