How to wire speakers without binding posts? How to wire speakers without binding posts? - diyAudio
Old 8th March 2007, 02:05 AM   #1
wixy is offline wixy  Australia
Default How to wire speakers without binding posts?
I'm in the process of building some fullrange speakers, and am planning on using Cat5 cable to wire them.
This is a technical question, how would I run the Cat5 cable out of the speaker boxes? i.e., what is needed to ensure that there is no gap around the wire when it is exiting the boxes?
Old 8th March 2007, 02:17 AM   #2
Elkaid is offline Elkaid  Canada
Elkaid's Avatar
Send a message via MSN to Elkaid
Do you mean some kind of grommets? Rubber or nylon perhaps ?
Grommets + Bushings
Old 9th March 2007, 11:48 PM   #3
Thanks. Not sure how I would install those, and would they really prevent all sound leakage?
Old 10th March 2007, 12:37 AM   #4
Ed LaFontaine is offline Ed LaFontaine  United States
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Quick and dirty...
choose a drill bit a little smaller than 1/4"....ooops!...about 5 mm. Stick the cat5 through and caulk with silicone on the inside of the cabinet.
Now, if you are going to handle (move) the cabinets much you may want to consider strain relief where the cat5 goes through the case. In which case drill an appropriately larger hole. I didn't bother...you may want to.
Old 12th March 2007, 08:02 PM   #5
Colin is offline Colin  United Kingdom
Yep, silicone sealant works well. You might also want to seek out deployable CAT-5 which is much more flexible than the standard stuff (more like mic cable) and easier to work with.
However, any particular need to avoid the binding posts? (I did it on one set of enclosures because they were ceramic and I didn't rate the chances of the back panel holding together if it had two closely spaced holes.)
Old 12th March 2007, 08:38 PM   #6
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
There is also putty or 'rope caulk,' which would be less permanent. I've used it many times. (Think chewing gum.)
Old 12th March 2007, 10:06 PM   #7
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
If you wish to eliminate the sealant, rope caulk or grommets and the possibility of required maintenance, run brass or copper screws through the cabinets and solder to them on either side. I have done that on the inside divider panels where I have no way of accessing them after the cabinet is sealed if and when maintenance may be required. I use brass screws only because copper are more expensive and IMO unecessary.
planet10 needs your help:
Let's help Ruth and Dave
How to wire speakers without binding posts?Hide this!Advertise here!
soldering binding posts and copper litz wire FrankDIY Everything Else 14 17th December 2009 05:12 PM
binding posts h_a Parts 21 12th January 2009 11:10 PM
Binding Posts ANDYLASER Swap Meet 7 23rd November 2006 11:33 AM
Binding Posts herm Multi-Way 7 14th February 2004 05:34 AM
Copyright ©1999-2017 diyAudio
