Hi there
I'm deliberating on using EV T350 as a tweeter for Lowther DX4 in 200Hz front horn I have to change diaphragm in one of the T350 and I'm deliberating if I should use 8 or 16 Ohm . Lowther nominal impedance is 8 ohm which would suggest sticking wit 8 ohm the problem is that since there is no low pass filter on lowthers only the cap on tweeter (crossed at ~10k) the drivers will be electrically in parallel from cross point (and lower down the slope ) Anybody sorted that out? Regards, L |
| B20 plus cheap helper tweeter - why? | Godzilla | Full Range | 6 | 4th October 2007 03:22 PM |
| Active Crossover for helper tweeter | Zero One | Full Range | 8 | 18th June 2006 07:52 PM |
| Ideal 'helper' tweeter | Nuuk | Multi-Way | 67 | 9th March 2006 12:19 PM |
| 1uf or 2uf for helper tweeter | bigwill | Full Range | 19 | 22nd January 2006 05:33 PM |
| Page generated in 0.06223 seconds (67.36% PHP - 32.64% MySQL) with 10 queries |
