Old 3rd March 2007, 06:02 PM   #1
inrank is offline inrank  United Kingdom
inrank's Avatar
Default Full range line array
from my other thread, it looks like i will buy my crossover components for my other project from america, madisound looks best.
and i was thinking as i am already getting stuff from there, should i get some other things while i am there aswell, and seeing that they have some very cheap drivers there that i could get for a line array.
it would be used at home (as i am uni with my tannoy cheviots) and wont need to go all that loud, was looking at....
Foster 5.25" wide range (up to around 5khz) $3! (say 8 per side and get a seperate tweeter)
HiVi B3S 3" $9.55 (4 per side)
would this be a good idea.
And this is not another one of my 'crazy' ideas
Old 3rd March 2007, 07:42 PM   #2
Gasho is offline Gasho  Croatia
Gasho's Avatar
I am thinking about same stuff.
I consider drivers like Aurasound NSW1-205-8A and NSW2-326-8A for line array towers.
Old 3rd March 2007, 10:18 PM   #3
adason is offline adason  United States
adason's Avatar
great idea!
i was experimenting with something similar with great results
http://www.geocities.com/Vienna/Oper.../aud-line.html
Old 4th March 2007, 01:08 AM   #4
A while back Parts Express has a deal on Pioneer 4 "
for 50 cents USd each.
At that time Bill Fitzmaurice put together a project
for those which he may still have at
billfitzmaurice.com
I bought int o the deal and got 16.
But I have only one completed box wired to the
specification but no tweeter treatments.
A bit of a discussion on my build is over in the
full range driver forum:
http://fullrangedriver.com/forum/viewtopic.php?id=1136
That build was slow going and just recently got it stood up and
playing. So I'm interested in tips for line arrays.
I had questions in the thread about box volume but also
wanted to do minimal cutting on some reused pieces to retain
some round over corners. I'm doing a/b comparisons with
a BIB as I write during a radio broadcast.
At this stage of things the BIB has it all over the line.
The line takes more volume to get going too.
Old 4th March 2007, 12:52 PM   #5
adason's Avatar
hi loninappleton,
my line array has no box, its open in the back
you are not going to get much bass out of 4" speaker anyway
why not open baffle line array
with subwoofer
Old 4th March 2007, 01:29 PM   #6
JandG is offline JandG  United States
Intresting...OB line array.. with bass augmentation...mmmmm I am thinking on this also.. Can you curve the top & bottom forward to reduce combing effect..? seems I Have seen this before on arrays..I have a spare ribbon pair that I could also use in the project.. just need to figure out which drivers to use..& get to 150-180hz
Old 4th March 2007, 01:38 PM   #7
tinitus is offline tinitus  Europe
Hi guys,
Please remember, if you do a closed or vented box, each driver should have its own seperate chamber, or maybe better split up in sections - otherwise you will get a nasty low end ressonanse, related to the tall box
Maybe three sections, with top and bottom tilted/slanted(?) forward
just my 2cents, good luck
Old 4th March 2007, 01:55 PM   #8
adason's Avatar
if you cluster your tweeters in the middle, or use just one tweeter in the middle of midrange line array, there is no combing effect
you can bend the front, I have seen it done, but I believe its way too much complication for questionable benefit
Old 4th March 2007, 08:26 PM   #9
inrank's Avatar
what about the....
Vifa Logic BC14SG69-04 $15
http://www.madisound.com/cgi-bin/ind....9858&pid=2142
Peerless SC14SG49-08 $15
http://www.madisound.com/cgi-bin/ind....9858&pid=2184
both go up to arround 4khz, what frequency does lobing start and what freq should i cross them to a tweeter, and how does the array of say 8 of the drivers effect the efficiency?
Old 4th March 2007, 09:25 PM   #10
Hi, I would think that Visaton FRS8-8 or FRS8-4 are the ones to beat - looking quite nice and at 10EUR ea you can afford a couple more
edit, or maybe better if you can find the Hivi A2S
Full Range Line array Efficiency and Impedance Question? rjp366 Full Range 10 23rd August 2009 06:42 PM
Jordan JX6 full-range line array bcherry Full Range 74 3rd April 2007 07:53 AM
Full-range line array? mazeroth Full Range 20 1st November 2004 03:47 PM
line array with full range drivers? leadbelly Multi-Way 9 25th January 2003 04:48 PM
Page generated in 0.10429 seconds (86.60% PHP - 13.40% MySQL) with 11 queries
