Old 19th February 2007, 08:21 PM   #1
jsaults is offline jsaults  United States
Default planet10 and others: 40-1197 open baffle mid
I was thinking of using these as an open baffle mid/ widerange. They are fully modified of course (damped, dammar and phase plugs).
My question is if I were to passively cross them to a woofer what do you think is the lowest I could go without causing problems associated with large capacitors?
I know this is a fullrange forum, but you guys are the most familiar with this family of drivers. Please forgive me for thinking of putting components in the signal path.
I think this driver has excellent midrange qualities and its efficiency make me think crossing it to a high efficiency woofer might be fun. Thanks guys!
Old 19th February 2007, 08:46 PM   #2
bigwill is offline bigwill  United Kingdom
I'll hazard a guess and say cross it somewhere in the region of 200-300hz to a nice efficient PA 15" woofer
Old 19th February 2007, 08:53 PM   #3
Speakerholic
Cal Weldon's Avatar
Dave let me use a pair of Coral holey baskets as an OB mid without complaining. Even gave me the idea so I'd bet he's OK with you doing it with the 40-1197's.
I agree with bigwill that 2-300 would be OK. 2nd order will give you decent power handling.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 20th February 2007, 12:13 AM   #4
TerryO is offline TerryO  United States
TerryO's Avatar
I'll join in and recommend at least 300Hz for a crossover point. A bit higher wouldn't hurt, but 300 will allow nearly a couple of octaves above Fs for the 1197. The higher you go the cheaper the cap will be and, as Cal pointed out, you gain power handling. Something else, and this is my opinion, with the value that you'll be using and the low frequency involved, I'd use a large non-polar electrolytic cap. I am pursuaded by my experience that you would be hard pressed to hear a difference. I'm older and my hearing isn't as good as it once was, but I've never felt it was very important for crossovers to use expensive caps. Inductors OTOH, can be heard and you'll want to use a fairly substancial AWG. I'd also look at an Iron Core Inductor if the price is significantly higher for an Air Core.
Whatever you do, the point is to have fun and learn.
BTW: keep us posted on your progress.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 20th February 2007, 05:21 PM   #5
Default Fs
Thanks guys for the input, I was hoping the Fs thing would come in to the conversation, I have also noticed crossing near there seems to do something funny to the sound, I did it once to some Tang Bands and the effect was not subtle. I will go for a second order for sure. Now for some budget high efficiency 15"ers. Suggestions? I don't need to go that low, I'd be happy with 30-40hz. I do have sizeable room gain, it's a small living room. I am running a tube buffered IGC.
Old 20th February 2007, 07:08 PM   #6
The Eminence Alpha or Beta 15 might do well. I'd recommend two per side for higher SPLs though, as they have a low xmax.
Old 20th February 2007, 08:39 PM   #7
Speakerholic
Cal Weldon's Avatar
I think that's where we part company. I think going with two is overkill for that little driver.
Arghh....that almost....killed me to ......say.
Budget? How about this place?
http://stores.ebay.com/101-WORLD_PRO...QQftidZ2QQtZkm
Old 20th February 2007, 08:49 PM   #8
I think a single Alpha or Beta will be better than any of those
Old 20th February 2007, 11:01 PM   #9
happy.gringo's Avatar
How about a pair of these Goldwood 12s for about the same price as a single Alpha 15? The QTS is 7:
http://www.partsexpress.com/pe/showd...number=290-392
Old 20th February 2007, 11:25 PM   #10
These have half the x-max unfortunately so although two 12" drivers have roughly the cone area of at 18" driver, the xmax is still halved
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
pics of my 1197 full-rangers executed by dave (planet10) faustian bargin Multi-Way 3 1st May 2003 12:31 AM
Page generated in 0.12490 seconds (80.65% PHP - 19.35% MySQL) with 11 queries
