QTS/OB explanation needed
Old 18th May 2010, 10:00 PM   #31
GM is offline GM  United States
GM's Avatar
Originally Posted by InclinedPlane View Post
I recommend avoiding drivers with a Q over 1.0 for the simple fact that the motor tends to be too weak to control the cone very well.
For a wide BW use, I agree, but (mid) woofer systems, not so much since if the correct baffle loading is chosen its roll off will damp the driver(s) somewhat.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 18th May 2010, 10:11 PM   #32
GM's Avatar
Originally Posted by Rudolf View Post
Forcing 70 times the energy through the low Q driver means reducing its control over the cone to the seventieth part of the original control.
Viewed another way, an OB is the inverse of a high gain TL, so as the long TL that only has the same pipe area as the driver's effective piston area (Sd) wants a strong motor (low Qts), the unfolded TL (OB) wants a proportionally weaker motor (higher Qts) and smaller baffle.
GM
Old 18th May 2010, 10:12 PM   #33
Don Hills is offline Don Hills  New Zealand
Originally Posted by DrDeville View Post
So underdamped systems produce more bass with less power, but roll off quickly and have a resonant peak at F3. Hum hum hum--and equalization can flatten the total amount of energy, but can't stop the overhang/humming.
I think you will find that equalisation does stop the overhang/humming. The secret is to match the equalisation to the resonance. If you have, say, a 6 dB peak at 50 Hz with a Q of 1.2, then applying a 6 dB dip at 50 Hz with a Q of 1.2 will correct it, both in frequency (continuous) and time (impulse) measurements.
Old 18th May 2010, 11:18 PM   #34
InclinedPlane is offline InclinedPlane  United States
InclinedPlane's Avatar
Well I should have said '.6-1.0 seems to be the range that provides the best sound to my humble ear'.
I must confess my favorite music is that made by the Rolls Royce Merlin.
Old 19th May 2010, 01:57 AM   #35
rjbond3rd is offline rjbond3rd
My head just exploded
Old 19th May 2010, 02:48 AM   #36
GM's Avatar
Hope it didn't hurt for long.
GM
Old 19th May 2010, 04:30 AM   #37
brookbh is offline brookbh  United States
So after reading this read and many others on OB over the past year or so, there seems to be several basic implementations of open baffle woofers:
1) high qts drivers like the alpha 15s, goldwoods, other in-exspensive drivers
2) low fs, high sensitivity pro drivers with a q around .3 to .5, higher x-max than alpha 15s or goldwood 18,15,etc..
3) drivers like the augie or AE dipole
So here is my noob question,I have seen a few members here and other sites suggest the sigma pro 18, how would go about implementing a low q driver such as this in a standard flat open baffle?
QTS/OB explanation neededHide this!Advertise here!
Current Mirror Explanation Needed. vdi_nenna Everything Else 33 7th July 2012 08:57 PM
Explanation for this problem? Rob11966 Tubes / Valves 4 22nd September 2007 04:39 AM
AC power connection schematic explanation needed Peter Daniel Pass Labs 20 31st July 2007 04:16 PM
Explanation of Self Oscillating Class D Genomerics Class D 19 29th October 2006 04:31 AM
CAT 5 cable explanation? Joe04 Parts 5 3rd March 2004 09:48 PM
Copyright ©1999-2017 diyAudio
