There have been several examples of people using fairly inexpensive PA drivers to augment the lower frequencies in OB speakers. An example is Martin J. King's Project 7(with Alpha 15A):
http://www.quarter-wave.com/Project07/Project07.html Even these large PA drivers(15 inch) are designed to go up to a few kHz, although in this application they are only used up to a hundred or so Hz. These drivers also tend to have fairly stiff treated cloth surrounds. What kind of changes would you expect if you replaced the stiff surround with a more complient foam surround? Increased VAS and Qms? Would the Fs change? Is the low frequency roll off usually seen on SPL plots of PA drivers (on infinite baffles) related to the stiff surround? I'm just wondering if a more complient surround could help a PA driver operate from Fs to around 150 Hz. Scott
"The Adobe Updater must update itself before it can check for updates. Would you like to update the Adobe Updater now?" -Adobe Updater |
#2 | |
But to a larger part it is due to the low Qes which is good for efficiency but bad for LF reproduction in infinite baffles and OBs. Regards Charles |
| augmentation stands..... | stuman | Multi-Way | 5 | 31st July 2008 06:44 AM |
| Does Audax AP080G0 need augmentation? | troystg | Full Range | 12 | 26th August 2007 09:03 AM |
| 21" Bass Drivers and Beyma Compression Drivers | Magnetar | Swap Meet | 0 | 19th November 2006 02:42 AM |
| Instrument drivers for OB bass augmentation . | JandG | Multi-Way | 0 | 5th November 2006 01:34 AM |
| WTB: KEF mid-bass drivers | markzb | Swap Meet | 0 | 30th June 2004 04:46 AM |
| Page generated in 0.07506 seconds (68.47% PHP - 31.53% MySQL) with 10 queries |
