Old 8th February 2007, 05:53 AM   #1
G is offline G  United States
G's Avatar
Default Beyma 12CX in a MLTL?
Anyone tried it? It should be perfect for the application. Maybe a good match for low powered tube amps.
Gavin
Old 8th February 2007, 03:35 PM   #2
freddi is offline freddi  United States
freddi's Avatar
ran one in ancient eliptoflex and a coupler = nice wideband woofer. might be suggestions for MLTL over at Jame's fullrange forum (?) IIRC Beyma recommended 50l reflex tuned to 50 (?)
Old 9th February 2007, 03:35 AM   #3
G's Avatar
The specs are supposed to be 45Hz - 20KHz. Why would you tune the cabinet higher? 50L is doable in my listening area. Would someone be kind enough to run a simulation for this driver? I don't have mathCad. BTW I think the spec sheet is wrong about the low driver having a sensitivity of 104dB 1w/1m. I believe it is 98 dB.
Gavin
Old 10th February 2007, 02:43 PM   #4
freddi's Avatar
I had to use what was laying around - Beyma's response simulation was for 50l & 50Hz tuning - am not sure if that chosen for falt passband. I would tune wherever it sounds best for most music tracks. Tuning above fs can sometimes sound more 'solid' - perhaps because the 2nd impedance peak is lower in amplitude than the first peak (?)
There should be someone "here" (or over at Jame's forum) game to simulate Beyma's 12CX in MLTL - I don't have MJK's sheets nor mathcad
my sample of 12CX had fs higher than 42Hz - perhaps it needed more break-in
Z-plot of coupler tuned ~42Hz
http://img224.imageshack.us/img224/5660/z12cx15js9.jpg
Beyma 12CX specs
http://www.diyparadiso.com/datasheet...beyma/12cx.pdf
Beyma's ~textbook crossover suggestion for 12CX
http://img133.imageshack.us/img133/764/xo1fa2.jpg
Beyma 8BX sumacSK Full Range 37 17th April 2008 10:08 AM
Beyma 12CX - PA only of usable for hifi ? Empee Multi-Way 3 20th August 2007 02:41 PM
Anyone using the Beyma 12CX in a MLTL? G Multi-Way 1 8th February 2007 01:47 AM
Enclosure for Beyma 12CX - whats good? freddi Full Range 0 24th November 2006 05:12 PM
Please suggest replacements for Eminence Beta 12CX Saurav Multi-Way 9 20th May 2004 04:27 PM
Page generated in 0.07853 seconds (71.81% PHP - 28.19% MySQL) with 10 queries
