#1 | |
Hi all,
I've finally decided to start experimenting with passive filter components with my FE127Es. This is out of curiosity, rather than the need to "fix up" the frequency response. A Zobel seems like a good starting point, as it'll make other filters easier to calculate, and aparrently will also reduce the gently rising response of the driver. I was just about to use MJK's Zobel / BSC calculation spreadsheet to come up with some component values, but I realised Fostex do not specify the voice coil inductance for this driver, it just says "N/A". Can anyone offer advice? I assume even if Fostex consider the Le extremely low, a Zobel is still worthwhile for my experiements, and required to flatten the impedance. A post on the full range driver forum states: Quote:
Best regards, Andrew. |
#2 |
I measured those values. They are higher than what I was expecting, so I qualified the measurments as you noted. When I put the LC meter on an air core inductor of known value, I get a reading that is very good. However, I can't help but think that the measured L is a little high. Surely someone else has an LC meter and a FE127E they can check. Cheers, Gio.
DIY Audio Projects [ 10" DIY Subwoofer | FE127E Sealed Bipole | [ LM3886 Chip Amp / Gainclone | K-12M Tube Amp Kit ] |
#3 |
Hi Gio,
Thanks for the reply. I should have mentioned who made those measurements :-) I think I should figure out how to use Speaker Workshop, or perhaps Arta, and do some impedance measurements with various Zobel components in place. I'll start with component values based on your measurements. An un-educated backwards approach? Yes. But hopefully it will tell me what I want to know. Best regards, Andrew. |
#4 |
I tried speaker workshop, but getting it going is not trivial. ARTA is much easier to use, but ARTA will not determine L. I don't suspect speaker workshop will measure L.
| HiVi B3s voice coil inductance - How to calculate? | chylld | Full Range | 2 | 15th January 2009 07:10 PM |
| Single Voice Coil Vs Double Voice Coil Subwoofer | Workhorse | Car Audio | 6 | 12th April 2007 06:36 AM |
| Measuring voice-coil self-inductance | Klimon | Multi-Way | 4 | 19th November 2006 12:23 PM |
| voice coil inductance VS transient response | kan3 | Multi-Way | 12 | 9th February 2004 08:18 PM |
| Voice Coil Inductance (Le) and Transient Responce | amo | Multi-Way | 11 | 8th June 2003 07:45 AM |
| Page generated in 0.07047 seconds (77.32% PHP - 22.68% MySQL) with 10 queries |
