Hi all,
I am new to this forum but a loooong time speaker builder. I am finishing up a T-amp and am looking for some small single driver speakers to use with it in my office together with a subwoofer. John Krutke's Tang Band W3-871S design seems like the best alternative for me. He has a new pair that he says is better and has superceded the Tang-Band design, so has pulled all the TB design data from his sight. However, I would like to build these anyway. They may not sound quite as good as the new speakers but I feel that I need to accept that in order to get higher efficiency. Does anyone have a copy of this design?? Or at least a schematic of the notch filter ?? I can handle the enclosure design on my own if that is not available, but it would be a huge time saver if someone already has at least the notch filter schematic, if not the complete design, that they can share. Thanks much, AudioSteve |
#2 |
Have you tried searching this forum? There are plenty of projects out there.
Audio DIY Page FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account. |
#3 |
#4 |
Zach,
Thanks for your response. I have tried looking everywhere. Vikash's site has everything BUT the notch filter. And the box dimensions are different (same volume though) as Johne Krutke's design; so the baffle step effect could be different on his box vs. Krutke's and the notch filter effect could also be a little different. Not 100% sure on that point though as I haven't crunched any numbers on it.h. The fail safe way to go would be to find both the original box and notch filter designs. Thanks very much, Steve |
#5 | |
Steve I also have the speakers but no cabinet. Vikash's speaker seems attractive but no info on the notch filter.... gychang |
#6 |
http://www.archive.org/index.php
It's maddening when old info goes missing. The WayBack Machine (thanks you Jay Ward) is a tool to search the internet archive. It may be a job of looking but there's the possibility that if the link was not specifically requested to be removed from the archive of all past and present websites it's there. I have a page printed on paper related to Zaphs projects for the WS 871. Copied off by hand it is: http://home.new.rr.com/zaph/audio/au...ker11-box1.gif It's a series of gifs that somewhere include the xo. I never built the xo myself. Happy hunting and enjoy The Wayback Machine. |
#7 |
Saved the page at the time.
It´s 270kB zipped. Got an email?
jens |
#8 |
#9 |
from: http://www.plastichead.net/audioworks/redir.php?m=speakers/speakmenu.htm&p=speakers/needles/w3s-871.htm
#10 |
In my opinion the notch-filter for the Cyburgs Needle will be well suited tfor most narrow baffle cabinets with the W3-871s. Just change the resistor and capacitor values to 6.8 as per Cyburgs corrected design.
The purpose of the notch is primarily to dampen a peak in the drivers response around 2.5 Khz. This filter also happen to roughly coincide with a suitable baffle-step compensation for narrow baffle cabinets. SveinB |
| Tang Band W4-1052sd full range drivers for sale. | type | Swap Meet | 1 | 17th January 2008 06:19 PM |
| FS: Tang Band 871s | jmikes | Swap Meet | 1 | 21st March 2007 03:34 AM |
| tang band full range line array, thoughts? | clearwaterms | Multi-Way | 5 | 12th December 2006 03:15 PM |
| Foam blocks between 2 Tang Band 3" full range on a small center channel | The Paulinator | Multi-Way | 5 | 27th March 2003 05:04 AM |
| Page generated in 0.10949 seconds (76.97% PHP - 23.03% MySQL) with 10 queries |
