Open baffle design help
Old 1st February 2007, 11:27 PM   #1
fin1bxn is offline fin1bxn  United States
Default Open baffle design help
I just received my EV SP12b drivers today and am torn between building the Karlson K12 cabinet or going open baffle.
I figure if I try the open baffle and dont like it I can always cut the wood to make the cabinet.
Looking for opinions, also if I do a OB i was going to use 48 high 24 wide, I wanted to know where should I cut the Hole? In the center or is listening hight ok (About 3/4)
Here are the specs
fs - 41
vas CFT - 6.27
qms - 5.9
qes - .69
qts - .623
re 9
le mH - 1.2
eff - 94.5
Bob
RN
Old 1st February 2007, 11:54 PM   #2
hitsware is offline hitsware
I'd put it in the center of the 24" dimension
(12" each side")
~30" from 1 end of the 48" dimension
BUT !
Put it on the floor on the 48" side I.E.
48" wide 24" high tilted up towards the
listening position.
(for better bass (this gives a shortest
diameter of 48" (Fb~90Hz) rather than
Fb~180Hz (shortest diameter 24"))
Old 1st February 2007, 11:57 PM   #3
chris ma is offline chris ma  Canada
chris ma's Avatar
Use the EDGE program to find the location of the hole..
The Butcher
Old 2nd February 2007, 03:55 AM   #4
Kensai is offline Kensai  United States
Send a message via AIM to Kensai
Getting it closer to the floor gets you more bottom end, but you will definitely need to tilt them to radiate toward your listening height. As for the the rest, its really more about the baffle width than the height, and you do not want equal distances from driver center to any 2 edges as that will cause either a hole or a peak at the frequency defined by the distance the front and back waves travel to meet at the 2 points that are identical. Generally I would suggest just go with listening height mounting vertially and then put the driver into the outside third of the horizontal space on either side (so that there is maximal separation between channels)
Kensai
Old 5th February 2007, 04:07 AM   #5
opnly bafld is offline opnly bafld  United States
opnly bafld's Avatar
(12" each side")
BUT !
listening position.
I agree with this.
Measurements I have seen indicate more problems with frequency response when the driver is offset left or right vs. centered.
Except, since you more than likely will want bass augmentation regardless of whether you place the baffle 48'w or 24"w, I would suggest 24"w(or less~18") for much better imaging and soundstage IMO.
Lin
Open baffle design helpHide this!Advertise here!
Open baffle design lawbadman Multi-Way 1 17th January 2008 01:15 AM
Open-baffle design question Aengus Multi-Way 6 17th May 2006 07:37 PM
Open baffle/ dipole design help Infinity buff Multi-Way 3 12th April 2006 03:19 AM
SPL in Open Baffle Design Kal Multi-Way 1 25th August 2004 11:52 AM
Open Baffle Speaker Design using BG Neo-8? Matt MacBeth Multi-Way 2 24th December 2002 04:44 AM
Copyright ©1999-2017 diyAudio
