Need advice on how to paint/add vinyl laminate to speakers
Old 24th January 2007, 10:59 AM   #1
Neville is offline Neville  United States
Default Need advice on how to paint/add vinyl laminate to speakers
I completed my horn speakers from Madisound and now want to get them to blend with the rest of my speakers and decor. I want to either paint them black or give them a black ash look which is available from partsexpress.com - they come in a peel and stick laminate or peel, lay down and use an iron material. Since I have never done any of these, I would like to hear your advice/experiences.
Painting it or staining it appears to be the easiest option but I do like black ash laminate
Thanks in advance
Neville
Old 24th January 2007, 03:24 PM   #2
no xo is offline no xo  United States
The vinyl laminate from parts express is almost the same a using veneer. I recommend placing sheets of waxed paper between the laminate (glue exposed) and the cabinet until you have the sheets of laminate exactly where you want them, making sure there is enough laminate to cover the pieces and excess to trim off. Start at one end adhering the laminate as you pull out the waxed paper, moving from one end, then around the cabinet. The waxed paper allows you to move the laminate around without sticking. Try to wrap as much of the cabinet with a large piece, to reduce the # of seams. If you have to have any seams try to make them on the back edges and not the front, where they are more visible.
Old 24th January 2007, 09:09 PM   #3
no xo, thanks for that advice, i did not think about seams until you mentioned it.
If I go to HD or Lowes, is there a dark enough stain to make it look black ?
Old 26th January 2007, 02:47 PM   #4
I use Ebony stain on most of the speakers I build, usually on the back or inside the mouth. It will take several fairly thick coats to get them really black, 3 to 5 coats with a paint brush and don`t wipe them with a cloth, just leave the stain to soak in. After I get the wood black enough, I seal them with a few coats of wipe on satin polturethane and the finish looks great. Personally I would use stain before I would use vinyl covering. You can always cover over the stain if you dont like it. And if you want a finished look, use some birch edge band over the plywood ends. Good luck, and post a picture of your work when you`re done. I have a couple pics of my horns on the HP Reflectors thread posted by a friend noxonewbie.
Old 26th January 2007, 04:01 PM   #5
chrisb is offline chrisb
You might want to treat the birch plywood with a pre-stain conditioner, to reduce the possibility of blotching.
Even with a dark & high solids stain, raw rotary sliced birch plywood is not the easiest veneer to finish, and darker colors can be the trickiest of all with which to achieve furniture grade results on any surface.
Old 26th January 2007, 04:27 PM   #6
Buckapound is offline Buckapound  United States
For stain, I would suggest an aniline dye rather than a pigmented stain. Generally much deeper color and even coverage. Try a source like Woodcraft. or Woodworker.com.
For paint, check out the range of textured finishes available as spray paints these days. Krylon's got a ton of them, available at home centers. Some of them are pretty cool.
--Buckapound
Need advice on how to paint/add vinyl laminate to speakersHide this!Advertise here!
Paint fading on speakers? Glowbug Multi-Way 3 17th July 2007 07:32 AM
Covering speakers with vinyl fabrics? sqlkev Multi-Way 15 3rd August 2006 11:07 PM
Vinyl Laminate ibanezcollector Everything Else 5 7th January 2006 10:32 AM
Best/Easiest spray paint for speakers? mazeroth Multi-Way 34 6th June 2005 04:26 PM
Digitizing Vinyl Advice tg3 Analogue Source 11 2nd November 2003 04:05 AM
