What should I do with these Philips Full Ranges?
Old 19th January 2007, 04:04 PM   #1
miccomacho is offline miccomacho  Finland
Default What should I do with these Philips Full Ranges?
Hey everyone.
I have six Philips AD 7080/m4 drivers. I got these for free. All are in perfect condition.
Does anyone have any information about those?
I don't know any parameters. Maybe I should try OB?
Comments...
(My english is quite poor and i'm sure there is some mistakes )
Mikko
edit. some pics:
http://img259.imageshack.us/my.php?i...m000790hg1.jpg
http://img259.imageshack.us/my.php?i...m000795vj7.jpg
http://img259.imageshack.us/my.php?i...m000796st6.jpg
Old 19th January 2007, 05:33 PM   #2
vinylkid58 is online now vinylkid58  Canada
vinylkid58's Avatar
Hi Mikko,
Those drivers look mint! Sorry, I have no info to offer, I have 4 of the smaller version, also free. They sound surprisingly good in OB, but not amazing.
I wouldn't try putting yours in boxes until you have more info, you could try OB first.
Jeff
Old 19th January 2007, 09:00 PM   #3
Dumbass is offline Dumbass  British Antarctic Territory
I'd try to get them measured at some point. Also, I think the paper surrounds tend to get brittle over time, so maybe some dope (silicone?) on the surrounds.
I believe they were taken out of some sort of TV or radio console and would therefore be designed for an open/infinite baffle type of use. I'll bet their Qts is somewhere around 1.0.
http://members.myactv.net/~je2a3/open.htm
Old 19th January 2007, 09:16 PM   #4
markanica is offline markanica  Netherlands
Default AD7080
Found some (minimal) info for your Philips Wide-rangers..
http://mfbfreaks.nl/artikel/lsinfo/1/images/pag09.jpg
Mark
Old 20th January 2007, 12:44 AM   #5
Klimon is offline Klimon  Belgium
They were more than probably made for open baffle. I've got some 4" Philips' with accordeon surrounds running in OB (be it 8/side in line array) which puts out quite some bass considering their size and small baffle...
Simon
Old 20th January 2007, 07:27 AM   #6
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I've only had 1 set of those thru here that i've measured -- the very similar 7060 seems more common.
Fs - 119
Re - 6.65
Qms - 7.18
Qes - 2.67
Qts - 1.94
Vas - 9.67
Cone mass - 4.76
Sd - 134.78
dB - 89.97
comp cm/dyne - 3.76E-07
BL - 2.98
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th February 2007, 04:25 PM   #7
Empee is offline Empee  Netherlands
Empee's Avatar
Hi!
I've got a pair of Philips AD3800AM's, wich are 7,5"
Mounted them in a pair of full-size Voigt pipes (2,44 Meters high)
do the same and you'll be supprised of how good these ol' drivers sound
If you want more info on my voigts, the discussion once started at:
http://www.diyaudio.com/forums/showt...pagenumber=131
cheers!
What should I do with these Philips Full Ranges?Hide this!Advertise here!
What full-ranges offer most midbass punch? CZ Eddie Multi-Way 21 19th August 2008 02:55 AM
TB 2" Full Ranges MiniVanMan Full Range 6 22nd June 2008 03:29 PM
Samco Full-Ranges mod_evil Full Range 2 24th March 2008 04:26 PM
FS: 1 pair Fostex FE-166ES-R full ranges zobsky Swap Meet 6 13th April 2007 06:57 PM
Full Ranges for Rock/Metal juan_caliente Full Range 17 25th June 2005 07:09 AM
Copyright ©1999-2017 diyAudio
