I remember reading a post that dismissed the M4N as a full range driver. Parts Express now lists this driver under the "extended range driver" section. In looking at the sample response curve, it looks very similar to the Hi-Vi B3S which I really like. Can someone explain why this driver wouldn't work as a full ranger?
Here's a link to the M4N: http://www.partsexpress.com/pe/showd...number=297-434 And here's the response curve: http://www.partsexpress.com/pdf/297-434.pdf |
#2 |
I think you're referring to this comment:
"Landroval The M4N is no fullrange. If you look at the responce graph you can see it's ok for a midrange, but anything over 5000Hz is impossible to fix. The 1,5k bump can be tamed with a passive filter. You should get the B3N instead: http://www.partsexpress.com/pe/psho...tnumber=297-428" Both types 'll probably give a forward representation; based on FR I wouldn't say one type could pass and the other couldn't. Zaphs Fr of the B3N looks surprisingly 'flat' on top when compared to the manufacturer's curve, even without the notch. Simon |
| Page generated in 0.06255 seconds (70.82% PHP - 29.18% MySQL) with 9 queries |
