A friend of mine and I are going to be building a set of speakers using the Fostex FE167E driver in a bass reflex enclosure. I have a concern that since the Fostex has an Xmax of 0.6 mm that there could be a risk of overexcursion using this driver with his 100W/channel receiver. I am thinking of using a high pass filter in the speakers to cross them over to his subwoofer. However, I am unsure of a couple of things. First, is there an easy way to determine the excursion of the driver at a particular frequency/amplifier power given a certain size enclosure and tuning frequency? Second, I would like to use a first order RC high pass filter to protect from overexcursion, but I am unsure of what exact values of the resistor and capacitor should be. Obviously I can calculate the product of RC, but I am not sure if there is a certain size of resistor/capacitor that should be used.
Thanks for any help. Cheers, Geoff |
#2 |
Unless you are playing the 1812 Overture at very loud volumes, I would not worry too much about this issue. For normal listening, even at very loud volumes, I have not had a problem with my Fostex and Lowther systems running full range powered by a 200 watt/channel amp.
If you really are intent in providing some protection I would recommend a small closed box with the volume set to provide an acoustic crossover (12 dB/octave) at the lower frequency of your choice. Simple, saves parts, less expensive, and less likely to be screwed up and more likely to perform as designed. |
#3 | |
DaveD (planet10) recently had a pair of quite small sealed boxes contructed for FE167s for exactly that purpose. They'll be serving as L&R mains for a complete surround HT system, with dual powered woofers up front (FE167 centre, and in-wall FE127 MLTLs for surrounds) It's always nice to meet a loudspeaker's acoustic goals with mechanical rather than electronic methods. |
#4 |
Thanks for the replies.
I guess I should note that these speakers are going to be dual use for music and home theatre. I've looked at a sealed enclosure, but I can't seem to get a f3 much below 125 Hz. I would like to get into the 60-80 Hz range with these drivers and that doesn't seem to be possible in a sealed enclosure. |
#5 | |
How low does it go?
...still looking for the holy grail. |
#6 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 | |
That system must sound sweet. Dave, that was to quote another canadian "just what the doctor ordered"! 100hz would just about make the grade. Q1: any reason for the sloped rear baffle other than standing waves? Q2; for the rear channels one idea could be to mount the driver on the sloped baffle and have the speaker "upside down" so that the speaker is mounted high on a wall and looking down. Do you see any merits/de-merits in this? After all this would only apply to the surrounds. edit... excuse me if these questions have been answered before in some FAQ?
#9 | |
frugal-phile(tm)
dave
| ML TQWT for Fostex FE167e | Raphael Shaw | Full Range | 55 | 15th June 2009 06:24 AM |
| WTB: Fostex FE167E | Studley | Swap Meet | 0 | 25th June 2008 06:46 PM |
| WTB : Fostex FE167E | Cacophonix | Swap Meet | 0 | 11th April 2007 10:49 PM |
| Aw ****. SI + Fostex FE167E | disconnec | Class D | 8 | 29th September 2005 12:53 AM |
| Fostex FE167E TL project | Lensi | Full Range | 17 | 6th May 2005 02:39 PM |
| Page generated in 0.12385 seconds (78.54% PHP - 21.46% MySQL) with 11 queries |
