anyone removed phase plug from TB W3 871S
Old 9th January 2007, 02:38 AM   #1
neutron7 is offline neutron7  Canada
neutron7's Avatar
Default anyone removed phase plug from TB W3 871S
If anyone has a busted one they would try it on? I think it is probably just threaded on a stud.
I had another speaker with a concentric tweeter which was attached that way, but you could see the bolt from the back of the speaker.
i want to machine some reflection cones for up firing them. and if they are bolted to where the phase plug gos it would be ideal
That way i do not need any frame or anything for the cone.
Old 16th January 2007, 09:52 PM   #2
MarkMcK is offline MarkMcK  United States
Sorry, glue is used. No threads.
Also, as you change the volume of air sitting within the cone area (replacing plug with dispersion cone) you will do all sorts of bad things to the transducer's performance.
anyone removed phase plug from TB W3 871SHide this!Advertise here!
Phase Plug, how does it works? Antonio Multi-Way 5 17th June 2009 12:05 PM
Phase plug seems to make a new BSC necessary. G Full Range 3 28th March 2008 06:05 PM
DIY phase plug, snug fit or not? jamesdb Full Range 2 20th June 2007 08:34 PM
making a phase plug? nerd of nerds Multi-Way 27 25th April 2007 03:25 PM
Anywhere to buy off-the shelf phase plug? bcherry Full Range 6 19th October 2005 07:22 AM
Copyright ©1999-2017 diyAudio
