Old 7th January 2007, 07:57 PM   #1
gychang is offline gychang  United States
Default metronome from RS40-1354?
Finally getting back into the DIY after the long holiday season.
I want to build a metronome and want to use the speakers that are sitting idle on my bench. Originally I was going to cut wood for TB W3-871S but the speaker is only 32" in height. Since I am used to building BIB speakers with higher heights, I like to know if the RS will be appropriate.
gychang
Old 7th January 2007, 09:46 PM   #2
Scottmoose's Avatar
For a Metronome? Oh yes. I haven't done one for the RS driver, but I'll see what I can come up with in the morning.
Old 8th January 2007, 12:00 AM   #3
thanks much.
gychang
Old 8th January 2007, 08:24 AM   #4
Scottmoose's Avatar
Internal height 60in. So = 3in wide, 1.5in deep. Sl = 10in wide, 7in deep. Vent in base 2in diameter, 2in long. Zdriver 30in. Line or stuff upper portion of cabinet. If stuffing, 0.25lbs ft^3.
Old 8th January 2007, 11:46 AM   #5
Am I interpreting this correct?
all inside dimension
internal height is 60" (vertical), center of the speaker at half way at 30".
top end plate: 3" wide, 1.5" deep
bottom shelf/plate: 10" wide, 7" deep
vent size in the center of bottom shelf is 2" diameter with height of 2"
will line the upper portion with 1/4" hardibacker (no stuffing)
thanks Scott,
gychang
Old 8th January 2007, 12:59 PM   #6
Scottmoose's Avatar
Smack on. Let us know how it turns out -this'll be the first pair with the RS40-1354.
Old 8th January 2007, 01:56 PM   #7
great!, thanks will put up the pics as usual.
gychang
A single 40-1354 out there? Smokehouse Bob Swap Meet 5 22nd February 2007 08:40 PM
Best cheap tweeter fo 40-1354? Spasticteapot Full Range 10 10th December 2006 10:41 PM
Sonic T-amp and RS40-1354 speakers, now which speaker box? gychang Full Range 12 26th August 2006 02:52 PM
Pics of my RS 1354 bipoles w/ PR 3-LockBox Full Range 8 2nd August 2006 08:24 AM
RS40-1044 8" Fullrange TQWT Design? hearing aid Full Range 3 13th April 2002 03:24 AM
Page generated in 0.10135 seconds (79.08% PHP - 20.92% MySQL) with 11 queries
