Thought I'd share a new set of fullranges I just received. They are the Lyeco 8" LY802F.
Driver specs - http://www.lyeco.com.tw/full%20range.htm I'll be doing some open baffle experimenting with these. I'm going to build a middle section that will be sand filled and add wings and a few other ideas for experimentation. Gary ![]() ![]() ![]()
#2 |
Have you measured the T/S parameters of the drivers? I would be very interested in seeing the real T/S parameters of each driver and comparing them with the published specs. and with each other as a measure of the manufacturer's quality control. The drivers look interesting, and some of the other models look real interesting, but without independent data I would not be willing to take a chance on them.
#3 |
I don't have the capabilities to do such things.
If anyone in Minnesota has let me know we could get together and try them out. Gary |
#4 |
Popped these in a small vented cab for a little break in today, and these drivers are going to have some real potential IMO.
Great clarity, excellent midrange and super highs. Bass hard to tell in the small cabinet, but so far so good. Gary |
#6 |
I dunno Bob. Normally I'd agree, expecially given the Qt, but Dave and I did a double BVR design for them, which according to MathCad at least, should work pretty well. Admittedly, it's not small though: 60in tall. And it assumes the factory specs., are correct, which is always a bit dodgy.
#7 | ||
Does anyone have thoughts on the ball diffusor vs. a phase plug? And, what's with the 4 whizzers? Max
"Part of the reason a poot into a toilet bowl sounds the way it does is because of phase shift." -Andrew Eckhardt |
#8 | |
Gary where did you order these from and how much did they cost?
#9 |
He won them in a recent competition on the Full Range Forum. Curse him.
There were some cracking designs that emerged in this comp., and all are well worth exploring IMO. I thought all the entries were great, with some real creativity in each cabinet / panel. Gary -how do you find the midrange on these beauties, especially for female vocal? As a big Loreena McKennitt fan, I'd be interested to hear your impression[s]. Scott P.S. FWIW, the double-horn cabinet Dave and I did is my favourite of all the BVR boxes that we've done so far, at least in terms of the modelled performance. I suppose it should be, given that I / we had the benefit of having designed the other three before it, so I was refining my approach (the CSS double BVR has also benefited from this). It'd benefit from some bracing in the chamber to reduce panel resonance, but should sound interesting! |
#10 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Where to buy Lyeco fullrange drivers??? | kyrie48 | Full Range | 1 | 22nd November 2008 02:29 AM |
| Where to buy Lyeco/Dynavox drivers?? | kyrie48 | Multi-Way | 0 | 19th November 2008 04:19 PM |
| First Impressions | Jhovis | Multi-Way | 4 | 19th January 2004 03:45 AM |
| Page generated in 0.12536 seconds (76.92% PHP - 23.08% MySQL) with 11 queries |
