Gentlemen,
I posted a message a while back for a "simple to build" enclosure for the Fostex FE 206 ES-R. From this post, I received a lot of good advice from Scottmoose for building a BIB -TQWT. He even did the calculations for me (thanks again BTW). So everything was ready to R&R. So I was all ready to go, except that I discounted the WAF in my plans : my future ex-wife threw a serious tantrum when she look at my plans and discovered that these beautiful boxes would be over 2 meter tall... Not planning to move out of the house in the near future and be forced to sleep in my car, what recommendations would you have for an enclosure taking care of the Wife Acceptance Factor. 1) Fostex recommended enclosure for the FE 206 ES-R ? as per the attached file. 2) A Nagaoka D58-ES ? 3) Others ?? Thanks, Sierra |
#2 |
That design is slightly different from the one posted on Madisound's website for the ESR:
http://www.madisound.com/pdf/fostexd...206esr-rev.pdf My buddy Frank recently completed a pair of these (quite a daunting task ), they sound fabulous, but make sure you have a furniture dolly handy to move. Even in baltic birch plywood instead of MDF, these are well over 100lbs each, and awkward to boot. The finished dimensions are 370mmW x 1071mmH x 532mmD |
#3 |
>>> future ex-wife threw a serious tantrum...
Build the BIBs. |
#4 |
Chris has pointed you to the correct Factory box for the ES-R. Much, much better than the cabinet for the standard FE206E. Basically, as you'll see, the ES-R box is a refinement of the Nagaoka D-58.
As an alternative easy to build cabinet, the Factory design for the FE208ESigma is a well designed box, and should do OK with the ES-R units. |
#5 |
When I look at the way the 206esr cabinet is built (and I’m sure it’s a great sounding system) I can’t help but realize how efficient the BIB design is. There is ‘dead space’ at the front and bottom with the back horn… with the BIB all the space is utilized (every single drop).
Whatever you build will be big. Explain to your soon to be ex that floor space is similar regardless of height. Sounds like she might complain about whatever you build. Good luck! |
#6 | |
Jeff is probably right, you don't want to set a precendent of submission, at least as far as the audio system/decor equation is concerned. Other areas of interpersonal relationships would be considered Way OT for this forum (any woman who says size doesn't matter, probably hasn't given birth multiple times) |
#7 | |
frugal-phile(tm)
You can send me the 206sERs for proper disposal. The BIB is almost for sure the best easy to build box, Bruce might edge it out overall, but it isn't going to be much smaller (and a more complex build -- less pieces than a Fostex box thou -- althou you might be able to dress it up better) ![]() dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
#9 |
Hey freddi,
That is a very attractive enclosure. How's it work. Are we talking about the RCA-Fan of Audio Asylum fame? Does he have any published plans for those? Rick |
#10 |
Yup. It's a sort of back-loaded expanding QWR with a Karlson slot. I've got the plans on my HDD somewhere. Er, here we are.
| Switching car audio enclosure to home enclosure | wattz | Subwoofers | 10 | 18th April 2010 05:51 PM |
| help, bmb cs 350 enclosure | triast | Multi-Way | 0 | 8th July 2007 09:38 AM |
| Convert horn enclosure to sub enclosure | chipco3434 | Subwoofers | 5 | 22nd December 2004 03:54 PM |
| the $5 amp enclosure | theChris | Chip Amps | 62 | 30th June 2004 01:29 AM |
| Page generated in 0.21337 seconds (47.06% PHP - 52.94% MySQL) with 11 queries |
