Old 29th December 2006, 07:26 AM   #1
jsb is offline jsb  France
Default Supravox 215 and backhorns
Dear all
I do not have enough room here to try the supravox 215 in OB (it needs about 2 meters from the wall to give its best) and I was wondering if it made sense to try and tweak one of the nagaoka or fostex (the 208??) enclosures for this driver?
From what I gather from the web, trials with the "universal" MJK MLTL needed a lot of tweak, so I was wondering if a good BLH would not be able to give a fine tonal balance?
Any hint concerning enclosures will be appreciated!
Old 29th December 2006, 09:42 AM   #2
Scottmoose's Avatar
Which 215 do you have? There's 3 of them, all with different claimed parameters & we don't want to make a mistake.
Old 29th December 2006, 10:08 AM   #3
Sorry, it's the basic one, the regular 215RTF64
http://www.supravox.fr/haut_parleurs/215_RTF.htm
Old 29th December 2006, 10:49 PM   #4
Scottmoose's Avatar
I'll get my thinking cap on. There'll be something interesting we can do with it no doubt.
Old 30th December 2006, 01:24 AM   #5
xcortes is offline xcortes  Mexico
I have the 215-2000 exc on open baffle and they're about 1 meter from the rear wall which, if my calculations are correct, is only 1/2 of the 2 m you say they need. I'm seated at about 3 m from them. I don't think they can sound better. OTT you could try the Supravox recommended tqwt. There's good reports on that one too. Here's the link:
http://www.supravox.fr/kits/tqwt215.pdf
Old 30th December 2006, 07:23 AM   #6
el`Ol is offline el`Ol  Germany
Search for the "Amygdala" at audiodiskussion.de. This is a nice hybrid between OB and Box.
Old 30th December 2006, 04:41 PM   #7
fred76 is offline fred76  Philippines
H jsb,
Here's what Scottmoose generously gave me offline for the non-bicone RTF64 Straight-MLTL:
Here's a rough one (internal dimensions):
42in line length
12.5in deep
16in wide
Zdriver 8in
Port 4in up from base; 4in diameter, 1in long.
0.25lbs/ft^3 stuffing in the first 30in. = .868lbs. Total
Bracing following Scott's 'swiss cheese' approach using the golden ratio cross-section.
I haven't built it but I have no doubt it would sound great... *thanks Scott!* Attached below is the Mathcad response he sent me.
fred
Old 30th December 2006, 05:26 PM   #8
Hey
Thanks to all!! I was thinking of a BLH as I
- need to have something "manageable" (no 1,70*1,70m thing)
- wish to avoid implementing BSC
But the Qts is of course devised for OBs.
I'd be glad to try the MLTL but I'm worried with the correction issue (it would be a pity to waste my KR842's 7 watts in a passive filter). I have now, running on my system, a couple of FE207 DBRs; they're quite good, and have more bass than enough, but the DBR enclosure reduces the efficiency, and the supravoxes are way smoother for voices.
There's no hurry, but having the drivers, I want to make sure I've something to build during the next break, in spring or summer.
jsb
Old 1st January 2007, 01:31 AM   #9
I don't mean to change the topic but could anyone of you Supravox users tell me about their sound? It is so hard to get information on these French drivers. Even in Paris i was unable to get an audition on this or the Fertin. PHY-HP where great but i really wanted to hear a modern field coil.
Back to the issue the field coil sound does anyone have an issue with beaming or being restricted to one type of music. Trying to justify trading my rebuilt QUAD 57'!
Thank you all, this is a interesting thread!
Old 1st January 2007, 10:14 AM   #10
Scottmoose's Avatar
Got an idea. You could try dropping them into the Viech chamberless horn. If you're worried that the volume isn't great enough, boost the width to 300mm rather than 250mm. Could be interesting anyway.
Fostex FE 108eS Backhorns Richard1957 Full Range 12 18th July 2009 10:47 PM
Bass + supravox 165 LB + JP3 azerty34 Multi-Way 2 16th January 2008 03:01 PM
Supravox OB tomitune Vendor's Bazaar 0 3rd March 2007 01:17 AM
Supravox OB InclinedPlane Full Range 4 2nd March 2007 10:07 PM
supravox 285gmf jensen +supravox fronthorn Jacobus Multi-Way 3 16th August 2006 12:15 PM
Page generated in 0.11136 seconds (75.38% PHP - 24.62% MySQL) with 11 queries
