I need advice. Proper horn for a 12"
Old 27th December 2006, 10:40 PM   #1
Binkstir is offline Binkstir  United States
Default I need advice. Proper horn for a 12"
If you saw my dayton rear horns in another thread, I'd like to do something similar but add a 10 on 12 inch horn loaded woofer for bass.
Tweeter,
dayton fullrange as mid range but use filters to steal the low frequencies for the eminence delta 10 or 12.
tweeter
dayton 5" fullrange
I'd want to horn load the bass speaker. Not sure the proper way to do it though. Rear load it like I did my other project, or maybe do a lascala type thing? Id want the bass to be stiff so you could feel it hit your bones, not that real low, loose stuff.
Help me. My saw blades are sharp and I'm willing. And hey, if the whole idea stinks.. you can tell me that too. I wont be offended.
Old 7th January 2007, 04:13 AM   #2
bobhayes is offline bobhayes  Australia
bobhayes's Avatar
I can't test this free eminence software myself, as I have a mac, but it might help you with your enclosures.
www.eminence.com/resources_designer.asp
You are likely to find that the bass system will be far more sensitive than the dayton you are using, but I can't find Thiele/Small parameters for dayton, so I don't know for sure.
Good luck.
Old 7th January 2007, 06:13 PM   #3
Man, what a cool site. I checked the spl of the drivers and you are right about sensitivity. I'm going to look for another midrange.
I need advice. Proper horn for a 12"Hide this!Advertise here!
Need advice on proper use of anode chokes. pietjers Tubes / Valves 3 5th September 2008 08:33 AM
Bi-Radial horn tweeters - what's the proper orientation? KT Multi-Way 2 29th January 2005 05:56 PM
"Total Aural Dissonance" - the proper metric? jackinnj Everything Else 11 26th August 2004 12:39 PM
