Help! Disappointed with Visaton B200
Old 17th January 2007, 12:15 AM   #61
v-bro is offline v-bro  Netherlands
v-bro's Avatar
Good one!
I do this with my ESL mid-treble panels, works great!
I use a piece of 'pritex' for it and put it in a half circle behind the panel, attached to the sides....knobs of the foam pointed towards the 'driver'...Glued pieces in the top and the bottom... It's like a 'foam enclosure'...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 24th July 2010, 09:29 PM   #62
galop is offline galop  Slovenia
can i use b200 in 3 sistem loudspeakers for mid range?I thinking to use 2 x kef b139 1xb200 and tweeter. Is this right way?
Old 24th July 2010, 10:07 PM   #63
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
db/W/m ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th July 2010, 08:15 AM   #64
chris661 is offline chris661  United Kingdom
chris661's Avatar
galop - this driver is designed to sound best on it's own, so it's more than capable of doing the bass and treble that other drivers may not. Introducing these extra speakers won't increase the bandwidth by much (that's the usual reason why tweeters/bass drivers are added), but there's likely to be some degrading of sound quality.
My work: www.grimshawaudio.com
Old 25th July 2010, 08:28 AM   #65
hm is offline hm  Europe
hm's Avatar
Default B200
Hello,
"this driver is designed to sound best on it's own"
thats right.
i have superb experience with the B200 in my sat-horns,
also to see at the measurements,
the B200 ist also available in my double horns very good,
specially useful for classic listeners.
http://www.hm-moreart.de
Old 25th July 2010, 10:06 AM   #66
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Yes and no. It depends what you want to achieve.
The B200 is well regarded, but possessing both a high Q and a high Vas, it isn't an especially easy driver to work with, and has some characteristics that bother certain listeners, particularly in its higher frequencies. Employing it as a wide bandwidth midrange driver however makes considerable sense, and you may effect a considerable improvement in system capabilities providing the crossovers are located and designed properly.
For example, crossing to dedicated bass drivers at, say, 200Hz will effect a massive improvement on the available dynamic headroom of the system. Horst demonstrates something along these lines with his statelite horns, which are intended to be run to about this point (or just below) and then hand over to bass units. Chances are you would also obtain far more useful bass extension into the bargain, as a single B200 requires a very large cabinet indeed (by contemporary standards) to produce a decent low frequency response. And crossing to a well-selected, quality tweeter at, say, 8KHz should also bring far superior high frequency results, with an improved polar response / dispersion and linearity. Note that in both these cases, the XO is outside the telephone band (critical hearing bandwidth, or midrange if you prefer) defined by Bell Labs back in the 1930s as stretching from 200Hz - 4KHz and amply demonstrated by the Fletcher - Munson / Equal Loudness curves, thus minimising XO related nasties. Both, if done well, should be inaudible in practice. That 200Hz point would suit the B139 rather well as it happens, as it is not a driver that likes being crossed much higher.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 21st August 2015, 01:46 PM   #67
SoundRight is offline SoundRight  United Kingdom
Of course they are designed for OB with a great high qts. Bit baffled by the comments about "dull" sounding filters...like the components have this quality all by themselves! Instead of all this subjectivist "appraisal" get yourself a Dats kit from Parts Express and measure the device in question....any simple free programme will give you the component values? Or use Xsim...(awesome..and thank you!!) Or of course forget passive (right thing to do) and go active...preferably dsp active. These are not the ramblings of a heretic, just someone who has been involved in professional loudspeaker design for too many years!!! (SoundRight - Excellence in sound quality )
Help! Disappointed with Visaton B200Hide this!Advertise here!
wtb (1) Visaton b200 nvrgdenuf Swap Meet 1 17th February 2010 03:46 PM
F/S Visaton B200 nvrgdenuf Swap Meet 4 31st August 2009 02:02 PM
Visaton B200 (x2) - UK Grumpy_Git Swap Meet 6 17th September 2008 11:31 AM
where can I buy Visaton B200 in USA ken mead Full Range 2 22nd May 2008 11:06 AM
FS Visaton B200 JohnnyBoy Swap Meet 3 24th October 2006 02:35 PM
