JX92S and baffle step compensation
Old 2nd December 2006, 02:11 AM   #11
Jim Griffin is offline Jim Griffin  United States
Neil,
I typically use Mills 12 watts non-inductive resistors for most speakers. Only for higher power speakers would I use multiple resistors to increase the power handling.
On coils I typically use 14 to 16 gauge air cored units for such individual BSC cricuits. For tight packaging I might use laminated core inductors for the most inductance in the smallest package.
Jim
Old 6th December 2006, 12:50 PM   #12
cs is offline cs  United Kingdom
Originally posted by Dumbass
....Most commercial speakers have some sort of baffle step compensation built into the crossover circuit. The speakers are "voiced" for an assumed listening environment; note how higher-end speakers have some sort of recommendation for where they should be placed, i.e. "at least three feet from any wall" or what have you.
Are you sure ?
Neither the Spendor speakers I use now, nor the B&W speakers I used previously have any such compensation. They just have standard cross-over networks, with a small amount of impedance compensation, to allow for the rising voice coil impedance of each driver.
Neither of these speakers sounds particularly bass-light, quite the reverse in fact !
Old 6th December 2006, 01:20 PM   #13
Dumbass is offline Dumbass  British Antarctic Territory
Originally posted by cs
Are you sure ?
Could also be compensated for in the tuning of the cabinet, if not in the crossover circuit. It all comprises a system, and manufacturers will be doing in-room measurements, multiple prototypes, etc etc, to make the speaker sound the way they want it to.
JX92S and baffle step compensationHide this!Advertise here!
When to use baffle step compensation? tmblack Multi-Way 28 6th December 2008 01:39 PM
Short TL as Baffle Step Compensation m@ Multi-Way 0 10th March 2008 10:07 AM
Baffle step compensation formula? bart_dood Full Range 4 8th July 2006 11:50 AM
Baffle Step Compensation Khron Multi-Way 4 16th April 2006 09:23 PM
Baffle step compensation in an active X/O sunil Multi-Way 0 26th October 2003 09:47 AM
