Old 20th November 2006, 08:28 PM   #1
HOEK is offline HOEK  Netherlands
Default FE 108E sigma
hello
Is it possible to use a FE 108 in br-box?
So yes what is the best internal volume?
regards
Old 21st November 2006, 10:15 PM   #2
Jaime is offline Jaime  Uruguay
Jaime's Avatar
You can see this .
http://www.geocities.com/dbr_audio/bs-100.html
The driver is very similar.
I write in English worse than Tarzan
Old 24th November 2006, 06:54 AM   #3
chrisb is online now chrisb  Canada
Originally posted by Jaime
You can see this .
Well, if you're talking about the current FE108EZ family vis a vis the FE103, they're both more than 3" and less than 5", and made by Fostex, but I think the similarities end there.
Not much bass to be had from the 108ES in anything other than a BLH type enclosure, but effortlessly stellar midrange almost guaranteed.
Old 24th November 2006, 08:47 PM   #4
jaime,chrisb
thanks for reply,
Im looking for a small cabinet (8-15 litres),
sealed of br with a fullrangedriver.
Old 24th November 2006, 09:30 PM   #5
try the FE127 in monopole MLTL , per:
http://www.diyaudio.com/forums/attac...amp=1153883724
since it's an MLTL, the length of line and location of driver are fairly important.
If space is not a consideration, the BIB would probably outperform the monopole.
Old 25th November 2006, 07:38 PM   #6
Jaime's Avatar
Very different?
FE103M
Fs = 80 hz
R = 40mm
Mo = 2.7 gms
P= 15w
FE108sigma
Fs = 80 hz
R = 40mm
Mo = 2.7 gms
P= 15w
Old 26th November 2006, 03:08 PM   #7
gmilitano's Avatar
Very different?
FE103M
Fs = 80 hz
R = 40mm
Mo = 2.7 gms
P= 15w
FE108sigma
Fs = 80 hz
R = 40mm
Mo = 2.7 gms
P= 15w
The big difference between the FE103M and the FE108S is Q.
FE103M is 0.35, while the FE108S is 0.22.
Old 26th November 2006, 06:45 PM   #8
Jaime's Avatar
Yes, but the FE108sigma WORK FINE in bass reflex !!!
The family is :
FE103 >>> FE103E
FE103 >>>FE103sigma>>>FE108sigma >>> FE108EZ
FE103 >>>FE103sigma>>> FE108SS>>>FE108ES>>>FE108ESII
Old 26th November 2006, 07:50 PM   #9
Are You sure that the enclosure of a FE 103E (6 ltr BR) is suitable
for Fe 108Esigma?
HOEK
108E Sigma vs. 126E cervelorider Full Range 14 3rd March 2009 07:43 PM
FE 208 Sigma Puffin Full Range 30 12th November 2007 10:05 PM
FE 108e Sigmas cheap pjanda1 Full Range 7 30th November 2005 01:05 AM
Fostex 108E Z drivers for sale robster44 Swap Meet 1 22nd November 2005 02:44 AM
Looking for schematic for Cal Sigma II Dac marsupialx Solid State 0 19th December 2004 01:14 PM
Page generated in 0.09795 seconds (83.14% PHP - 16.86% MySQL) with 10 queries
