Old 18th November 2006, 10:45 PM   #1
jzagaja is offline jzagaja  Poland
Send a message via Skype™ to jzagaja
Default Horn loaded JXR6 which contour HOM suppression
Oblate spheroid is a good choice for flat wave input (compression driver). What about cone speakers? Is there any contour that is more suitable?
I need more waveguide than a horn so maybe this is a matter of proper phasing plug (which one?). Geddes in OS waveguide uses 30ppi open cell polyurethane foam but I'm not sure if this is a HOM suppression or a phasing plug.
Old 22nd December 2006, 09:11 AM   #2
Jordan JXR6 has a cone breakup at 2800Hz. It is a resonance that can be annoying in a horn systems (see Bert website, Oris horn) however I cannot say that it is bad after listening my raw driver:
http://www.audiostereo.pl/zalaczniki/670986_1.gif
As you can see the decay <1,5kHz is superb. If we attach front horn then we amplify the mid bass and its rising freq. will help.
What do you think using it in free air with horn? Is it dangerous for the driver working without restoring force?
Corrected JXR6:
http://www.audiostereo.pl/zalaczniki/671895_1.gif
Best Regards and Merry Christmas,
Old 29th December 2006, 08:53 PM   #3
Horn loaded JXR6 seems to be promising. As expected the amplified frequencies lies on 2Fs/Qe=~500Hz. CSD is very good - better than disc like enclosure I made without taking care of vibration control.
See:
1) Disc like enclosure, ground measurement:
http://ucz.tme.szczecin.pl/~jacek/te..._vibration.gif
2) Horn loaded:
http://www.audiostereo.pl/zalaczniki/676751_1.gif
3) Rise time example:
http://www.audiostereo.pl/zalaczniki/675250_1.gif
Happy New Year 2007!!!
Old 18th October 2010, 08:46 PM   #4
Bill poster's Avatar
jxr6 resonance at 2800 hz? was thinking to use this for front horn.. will this break up be noticeable?
Old 18th October 2010, 09:05 PM   #5
Don't waste time on horn loading - phase cancellation is huge. Better take 8" or 12" bass driver from Bandor. Horn requires compression driver.
Group buy list: http://www.diysoundgroup.com/
Visit us at http://www.horns.pl/
Old 18th October 2010, 09:11 PM   #6
Ah ok- I have only seen the jx92s in front horns - so the smaller driver wouldnt work.. I wanted to try it in an Oris type horn or rectangular horn down to 250 hz or so, then cross over to a 15" pro speaker in a BR
Old 18th October 2010, 09:21 PM   #7
Larger JX92 will be even worse. Do you have any SPL plot for Jordan+horn? It will have falling response and large dip on the mids. Whizzers are different - it's like horn in a horn. Usually such a fullrange in a front horn sounds unaturally big. I don't have Jordan but have 350Hz horn so I can check with 2" fullrange if I find one.
Old 18th October 2010, 10:09 PM   #8
So wd you class a tannoy westminster as a full ranger? Of course its a much bigger unit and I think the rectangular front horn section goes to 250 hz or so, altho its quite a shallow profile
Old 19th October 2010, 06:16 AM   #9
Tannoy Dual Concentric is a very nice coax - a true classic. WLM for instance uses cheapest Emminence coax with GDWT compression driver and people love them even if they measure so so. Cone speaker can be used rather as a midrange only. Dome tweeter or ringradiator can be used in a horn with very good results but compression driver offers extra gain and headroom. Few years ago I had JXR6 and Bandor 150. Hope that helps.
Old 19th October 2010, 09:30 AM   #10
I'm a bit confused - 'horn within a horn' etc.. whats the difference between a small fostex driver and a jordan FR in a front horn, ie not performance, but physically they are similar, right?
The design, contour, shape of the front horn makes a huge difference to the sound - can lead to a closed in or too 'in your face' sound
horn loaded driver Z AndrewT Multi-Way 21 23rd December 2007 05:32 AM
Mass loaded horn? cheesehead Full Range 79 25th September 2007 06:59 PM
Front loaded and back loaded horn DrWoofer.com Subwoofers 0 3rd August 2007 06:55 PM
KEF B200-G horn loaded B.I.G Multi-Way 1 5th August 2004 10:08 PM
Need help with horn-loaded sub slicemaster101 Multi-Way 26 17th September 2002 01:09 PM
Page generated in 0.11915 seconds (74.97% PHP - 25.03% MySQL) with 11 queries
