Is there anything else needed to build a full range speaker other than some cable, a cabinet, and the driver itself?
#2 |
Speakerholic
It depends on the cabinet and the driver. Some drivers sound better with baffle step compensation. This is used to tame the high end and allow for a better bass response.
Or it might need a notch filter that attenuates only certain parts of the frequency spectrum. This is used to smooth out the frequency response. To answer your question, no there isn't anything other than wires and a box needed but depending on the driver, the above two are options. |
#3 |
Cable, driver and baffle only are sufficient !
/Erling |
#4 |
i prefer high end over low end. im not very Bass-y
#5 |
Speakerholic
Try it without anything and see what you think.
#6 |
pardon for the stupid question, buts what exactly is a baffle?
#7 |
Speakerholic
Baffling isn't it?
A baffle is the board on which you mount the speaker. |
#8 |
ha. oh ok. seems simple
#9 |
If big league over blown bass in not a consern for you . Open Baffle might be your best bet. just wire, baffle, driver. You are done....BSC & or a notch filter will depend on how the driver behave's & if you like it as is or not...many vintage drivers do this OB exeptionally well. & there is many modern drivers that do also.Have you tried fullrangers before..?
#10 |
When I had my "top end" on open folded baffles, I found they wanted to be at least 3 ft from the wall. That's why those drivers have new cabinets, I don't have the room. You need to consider the listening room first.
One advantage of trying open baffles is, if for some reason you don't like it, the timber can be cut for a cabinet. You will also want some t-nuts and screws. That's the big advantage of wide range. |
| Frequency range of the human voice & full range center channel speakers | jwmbro | Multi-Way | 31 | 20th January 2008 03:07 PM |
| 1st order filters/crossovers with proper drivers compared to full range? | tech.knockout | Multi-Way | 8 | 15th May 2006 06:52 AM |
| what is FULL RANGE? | mrnedrub | Full Range | 2 | 21st February 2005 12:21 PM |
| Page generated in 0.09257 seconds (73.57% PHP - 26.43% MySQL) with 10 queries |
